05-24-2015, 07:22 | #5287 (permalink) |
Junior Member Join Date: Aug 2010 Location: Dubai UAE
Member: 1376246 Status: Offline Thanks Meter: 0 | Hi GSM-Furom, I am new here and i have a problem with my customers iphone 4s, stop restoring and then error 1...is there any other way to fixed this kind of problem ? As I search in google it is a baseband ic problem. Please help me,Thanks a lot.. |
05-26-2015, 02:10 | #5289 (permalink) |
Freak Poster Join Date: Sep 2012 Location: So. Cal.
Member: 1817612 Status: Offline Thanks Meter: 13 | This because there is a short on the motherboard. The battery protection circuit on the battery pack will limit or disconnect the battery if a high current load is encountered. Troubleshoot this problem with an external current limited supply while feeling both sides of the motherboard for heat being dissipated by the shorted component. If no parts are getting hot, look for a shot or solider bridge throughout the board using microscope. Chances are it is a shorted cap., but note you should remove all shields to check for component heating and for other shorts on the board. You must use a high quality scope or you are likely not be successful completing this repair. |
05-27-2015, 18:33 | #5291 (permalink) |
Junior Member Join Date: Jan 2010 Location: Worldwide
Member: 1215968 Status: Offline Sonork: 100.1651297 Thanks Meter: 11 | hey brothers i have a i phone 5s..its came for lcd change i just change lcd and did i not put any screws...and i check it its only showing apple logo and then black screen.. any solution for it. pls reply fast |
05-28-2015, 05:13 | #5292 (permalink) |
Junior Member Join Date: May 2015
Member: 2400377 Status: Offline Thanks Meter: 0 | Iphone 6 Touch Screen and Power Issue I have bought a couple of broken iphone 6's and am trying to make a good one. I replaced the logic board in an icloud locked one (with matching home button) and installed a replacement screen. It came on (with the previous owners home screen) and the touch screen worked, I didn't know the pass code, so I did a DFU reset and now no touch screen response at all, and the power is switching off after about 5 minutes of none use and the only way I can get it back on is to do a power/Home reset. Any thoughts? |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
