01-28-2016, 16:34 | #5566 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1351606 Status: Offline Thanks Meter: 1 | |
01-29-2016, 12:56 | #5570 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1524789 Status: Offline Thanks Meter: 0 | iPhone 6 SIM Issue "Searching..." & "No Service" Hello, I'm having a strange issue with service on an iPhone 6. I purchased phone for repair & resale. It had a badly damaged screen/LCD, so was dropped. After replacing screen & testing phone, I found that MOST of the time it will not find service...will display either "Searching" or "No Service". I've swapped 3 to 4 sims out several times. Most of the time it shows "No service", but only 2 of the 4 sims actually have service. Once it finds the service, it stays locked on to it till I disconnect the battery. I noticed in the settings under Airplane mode...when it finds service the "Carrier" line will pop up for a few seconds, go away for a few seconds, show again a 2nd time, then go away & the sim will show service. When it's not working...the "Carrier" line is never displayed. I've tried the following: Cycling Airplane mode several times, resetting Network settings several times, made sure antenna next to batt connector is properly connected, Date & Time setting, hard reset a few times, & did a factory reset. Nothing works. What component or circuit area would likely cause random service like this? Any help would be greatly appreciated. |
01-29-2016, 13:13 | #5571 (permalink) | |
Junior Member Join Date: Nov 2015 Location: Hungary
Member: 2492116 Status: Offline Thanks Meter: 0 | Quote:
01-30-2016, 13:22 | #5574 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2294424 Status: Offline Thanks Meter: 0 | My Iphone 6 is international model , but it show no service and when I disconnect the battery and reset network it works fine, but maybe 5 hours it no service again, anybody help me please! |
02-05-2016, 15:27 | #5577 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1637984 Status: Offline Thanks Meter: 0 | 4s Searching then no service 4s Searching then no service, blue coil pass, signal pass from dock antenna to black gsm's ic middle connection, all happened after screen replace, date etc are ok many times restore, put sim on another phone (sim works) tried many other sims, phone not blacklisted,checked, purchased a new sim , reset network , tried everything with no luck THE MESTERIUS thing is that with a freind sim with same carrier i am getting 5 signal bars , he had a nano sim and we checked it with a sim adaptor , so today i went to replace my micro with a brand new one nano sim just in case,still no luck, all sim connectors feet are passing well and good soldered in logicboard,imei is ok ,everything works fine but no service, What is that??? its driving me crazy , any ideas ? plz help |
02-06-2016, 23:40 | #5580 (permalink) |
Freak Poster Join Date: Dec 2015 Location: Taranaki, New Zealand
Member: 2499740 Status: Offline Thanks Meter: 11 | anyone no about theses errors . Brought this 2nd hand iphone 5c , it had a searching error when I put the sim in . then came up with error 1 then 18 then 4014 then error 4013 ? any ideas , im running the latest itunes and running win 7 |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
