11-04-2017, 09:19 | #6226 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Hubli
Member: 2535439 Status: Offline Thanks Meter: 14 | Sent from my SM-J700F using Tapatalk |
11-04-2017, 19:17 | #6228 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1972075 Status: Offline Thanks Meter: 1 | iPhone 6S after water damage, taken off all looking nasty components now straight after power button is around 250mA. After some while PM IC is slowly becoming warm. Can anybody had similar problem? |
11-13-2017, 10:58 | #6231 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Paris
Member: 333669 Status: Offline Thanks Meter: 7 | Hi gentlemen, i have an issue with my iphone 6s. To start the iphone I have to disconnect the battery and put it back once or twice. sometimes I do not need to remove the battery to start it. I try with another battery, the problem is the same. Other than that, it works properly. If I turn it off, I have one in 10 chance to turn it back on. The chassis was twisted a bit, I put the motherboard in another frame. do you have any solutions? |
11-13-2017, 15:32 | #6232 (permalink) |
Freak Poster Join Date: Jul 2007 Location: in your heart Age: 37
Member: 557167 Status: Offline Sonork: 100.1626163 Thanks Meter: 12 | i have iphone 6 that is battery jumped.. i replaced another battery with 45% original charged. but show it 1% and i plug charging cable battery % automatic reached normal but no increase battery %..like fake charging..and some time restart the phone and battery % show 100%... i replace u2 ic 3 time 'u1700' i also jumper q1701 and changed power transister u1401 replace charging strip. and also replace battery tarminal.. BUT NO LUCK ANY IDEA PLEZZZ |
The Following User Says Thank You to kawish For This Useful Post: |
11-17-2017, 12:00 | #6234 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2779640 Status: Offline Sonork: gcstorebali Thanks Meter: 0 | iphone 6 totaly dead hlo i have problem with iphone 6 totaly dead, if I give a voltage of 5.1v ... at j2523 ampere meter only at 0.07 and down to 0.03 and repeat like that. has anyone ever found such a case? if i unplug ic u1700 iphone do not want to turn on tnx u for help |
11-19-2017, 23:25 | #6235 (permalink) |
Member: 2779308 Status: Offline Thanks Meter: 0 | Hi iPhone 6 has crack in screen and for some reason it keeps glitching out http: // tikio. esy. es/ wp-content/ u ploads/2017/11/IMG_5691. jpg http: // tikio. esy. es/wp-content/ uploads/2017/11/IMG_5693. jpg |
11-22-2017, 10:45 | #6236 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1511020 Status: Offline Thanks Meter: 0 | Hi Folks Very strange problem! iPhone 6 suddenly boots boots for 30 seconds, then goes into recovery mode with black screen and with backlight (Not DFU) the phone is not waterdamaged, I have inspected the board under microscope of course, and no problems to be seen. U2 measurement are good. Anybody experienced the same problem? |
11-22-2017, 12:17 | #6237 (permalink) |
Member: 2781393 Status: Offline Thanks Meter: 0 | Hello. I have an iPad 4 on iOS 10.3.3. The thing is the device is slow with this iOS and I would want to downgrade to 9.3.5 or 9.0.2 . Is it possible? I can't run TinyUmbrella on my pc to check for older SHSH blobs because TinyUmbrella crashes at boot with a Java related error. Can something be made? Thank you! |
11-24-2017, 02:14 | #6238 (permalink) | |
Member: 2535439 Status: Offline Thanks Meter: 14 | Quote:
Try to heat 4.5 secand pm ic i hope ur problem wil b sovl. Sent from my iPhone using Tapatalk | |
11-27-2017, 18:05 | #6239 (permalink) |
Member: 2781163 Status: Offline Thanks Meter: 3 | Hi Guys So i've got an iPhone 6 that stays on the apple logo with a white background, plugging it into the PC does nothing, works fine on other phones, cable is ok etc. The PC just wont recognise the phone. It does seem to react when plugging it in from the off state to the white apple logo but not in itunes etc. anybody help ? |
11-28-2017, 09:35 | #6240 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2641303 Status: Offline Thanks Meter: 0 | iPhone 6S, no charging/connection through port. Changed original port and battery but still have issue. (Charging adapter/usb is also original and tested.) Any solutions? Best regards, iDevice! |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
