Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-18-2012, 10:56   #3016 (permalink)
Member: 1671373
Sonork: waqz
Hi,
Sir i have problem in iphone 3gs and iphone 4g, the ringer is working in normal way, but when we connect a call, during call the ringer, hearing speaker and handsfree don't work.
Plz help me to solve this problem permanently.....
Old 02-18-2012, 12:34   #3017 (permalink)
Member: 937918
Sonork: lepper4
Originally Posted by limespirit View Post
I dont have an idea why now its working because by defaults the 3GS fl7 is just solder pads. Anyways tell your customer to take photos, set full brightness, use gps and a lot of 3g also set the auto lock to never since this uses the iphone at full hence decreasing the battery immediately and hence we could see whether the iphone is capable to deplete the battery without problems
Its been a few days now iphone 3gs working fine only when i updated ios it has no service displayed baseband 05.16.05 bootloader 6.4 anyway apart from this iphone is working just have to unlock then another happy customer. Thanks Limespirit
Old 02-18-2012, 13:25   #3018 (permalink)
Member: 585903
usb not recognised in 3g
Old 02-19-2012, 10:30   #3019 (permalink)
Member: 750118
Sonork: koushalvikas@rediffmail.c
i have ipod touch 2g i insert charger after that it dead n start heating i remove battery but thyen again i attach battery it heat so i remove how to solve any schemativcs
Old 02-19-2012, 13:57   #3020 (permalink)
Member: 1009659
hi guys .. have a iphone 4 with water damage. have clean the pcb with isoprophanol
Now I have the problem that the pcb around the power ic getting hot and it will not turn on.
is the power ic faulty or something else. need your help
Old 02-20-2012, 05:13   #3021 (permalink)
Member: 1678566
I have a 3GS that is just dead.
Checking voltages I get 0 V on BB Vsd1 Supply and VSD2 everything else is fine.
Any ideas?
Old 02-20-2012, 05:28   #3022 (permalink)
Member: 1678566
Any ideas?
I put in another 3GS and I got the same voltages except the other one started and later on gave voltages on BB Vsd1 and VSD2 but the first one fails to start. Dont know why
Old 02-20-2012, 14:25   #3023 (permalink)
Member: 405731
3gs 32 gb charging prob.
hello! i have iphone 3gs who have charging issue wen i connect the charger display show only charging icon like low batt i saw lot of pics for this solution who have 2 charging ic remove and make jumper i did in 3g but in my board have only 1 charging ic i remnove it and make jumper but my fault is still so plz if u have any solution then i m waiting thanx in advance.
Old 02-20-2012, 18:22   #3024 (permalink)
cdma-india's Avatar
Member: 98139
hi Wites plz help big problem....
i have one 3gs serching for network so i told my one student to remove metalik shield from board by mistake he remove shield as well as complete shield border with nail cutter after fitting in housing now iphone is in recovery mode ( cable icon ) 100% hardware i think some tracks broken when he remove border of shield, plz can u give me some clue what tracks cause recovery logo ( i mean which part cause recovery logo) i dont have picture but u can help me giving some idia?
thanks
Old 02-20-2012, 22:13   #3025 (permalink)
Member: 1451453
3GS re***** after 10-15 min and needs activation
Hello, maybe anyone has experince on this fault : I have a 3GS which re***** after 10-15 min use and after the reboot it needs to be activated. It's a factory unlocked iPhone.
I have changed the battery to another, known good battery, but error still there. Does anyone have some idea ?
Thanks
Old 02-20-2012, 23:04   #3026 (permalink)
Member: 411253
i think its a problem with your PMIC, i have faced the same problem and had to change the PMIC but mine was 3GS,
Old 02-20-2012, 23:17   #3027 (permalink)
Member: 411253
iphone 3gs no service
i have one no service 3gs replaced everything related to network and still no service neither in gsm nor 3g, while searching i found someone fixed his no service 3gs by reballing the BB ic. so i removed the BB ic (not the first one i have replaced a lot for unlocking) but in this one there are some pins missing on PCB, i need a schematic diagram to check if the removed ones are useful or not. also i have tried to dig a little from pcb to check if can get my hand on the tracks, but i couldnt find any under the broken pins, what do you think the problem is,?
now i get that no imei no.. .. ... .. problem..
any solution or is there any unused pins under BB ic.
Old 02-21-2012, 09:16   #3028 (permalink)
Moderator
Wites OM Tesla's Avatar
Member: 1017374
There are a lot of unused prints if you not see any track or coper dot under removed ones no need to worry.
The Following User Says Thank You to Wites OM Tesla For This Useful Post:
Old 02-21-2012, 09:22   #3029 (permalink)
Member: 1176031
Thanks
Restore the phone to stock 5.0.1 and set up as new phone. Experienced this a while ago. Looks like there was a corrupted backup. Also make sure you are using an approproriate sim. This can happen if the phone is locked to a carrier and the iphone happens to know that the sim is not supported hence the activation screen.
Old 02-21-2012, 12:23   #3030 (permalink)
cdma-india's Avatar
Member: 98139
hallow wites help man
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 36 12-01-2012 14:21
lot of china mobile hardware and software solution here gsmkishtwar Chinese Models & Cloned Phones 6 06-24-2010 19:03
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.47844 seconds with 12 queries
