10-05-2014, 06:56 | #4967 (permalink) |
Freak Poster Join Date: Sep 2012 Location: So. Cal.
Member: 1817612 Status: Offline Thanks Meter: 13 | Try using a DC POWER SUPPLY, much better in isolating shorts. Check capacitors around U201 and PMU. Touch components suspected for excessive heat during short condition using DC power supply. |
10-05-2014, 08:59 | #4968 (permalink) |
Junior Member Join Date: Oct 2007
Member: 619497 Status: Offline Thanks Meter: 1 | Hi there, I`m having trouble with a water damaged iPhone 4S, only thing happening when connected to USB is that the power IC is getting hot, no iTunes connection or whatever alive on the PC or iPhone. Any ideas on what to do? |
10-11-2014, 14:15 | #4971 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2271687 Status: Offline Thanks Meter: 0 | iphone 3gs not charging not detected in pc, white screen Hi i have a problem with this phone after i change the battery apn 616-0434 with new one with apn 616-0435, after i put the new battery the phone starting ok but with white screen and sounds when i press home button, when i try to recharge battery the phone is not charging not recognaized by pc/itunes and no make sound when i insert the charger or usb to pc, i have a multimeter digital 7 functions, how can i test the dock connector port for right voltages to motherboard? I think the dock conector is broken, any instruction to test only the dock conector without motherboard? Thanks |
10-11-2014, 22:36 | #4973 (permalink) |
Junior Member Join Date: Aug 2013 Location: washingtoindc
Member: 1995710 Status: Offline Thanks Meter: 1 | My iphone 5s got wet, now its on and working but it keeps saying searching and wont stop even if i put it on airplane mode.. any suggestions??? Thanks. |
10-13-2014, 10:28 | #4975 (permalink) | |
Crazy Poster Join Date: Aug 2010
Member: 1358006 Status: Offline Thanks Meter: 7 | Quote:
1) Insert a working sim in your iPhone 2) Go to "SETTING" 3) Select "Carrier" 4) see if the carrier information is available, if you can see the carrier and select it your problem isent hardware but a blocked Imei! If you not found any network then your problem is hardwere, then you will try to change : 1) antenna flex 2) Blue coil 3) Gsm module. Try & let me know K.R Furqan | |
10-13-2014, 10:41 | #4978 (permalink) | |
10-13-2014, 23:09 | #4979 (permalink) |
Member: 2273643 Status: Offline Thanks Meter: 0 | Temperature Alert; cant get passed lock screen Hey there, I recently dropped my iphone 5 and since then I am not able to unlock my phone. After dropping the phone it came up with a temperature warning on the screen saying the phone needed to cool down. After restarting it multiple times the phone is able to recieve notifications which I can view from the lock screen and accept phone calls. When I try to unlock the phone it will let me enter the passcode but wont let me into the phone itself. I have tried connecting the phone to my computer but it wont stay conncected long enough for me to do anything. I put the phone into recovery mode and tried restoring it to no avail. I am out of warranty and a repair would set me back $260. I have an upgrade in exactly 3 months so I dont want to drop that kind of money on a phone I wont be using shortly. My prediction is that when I dropped the phone it either damaged the sensor that registers the temperature or knocked it loose. What are your thoughts on this problem? |
10-14-2014, 13:45 | #4980 (permalink) |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | Hello Today i buy new iphone 6. that time the version was 8.0 so i was try to update from setting but its gave error in installation. then try to update via file but its gave error 53. already change the host file and every thing. but same problem. already try with 8.0 and 8.02 but same problem. any solution.. bro |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
