Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 04-29-2016, 20:57   #5701 (permalink)
Member: 2380252
Iphone 6 plus faulty touch
When I slide my finger to log in, it doesn't work, so no touch. Do I replace the touch ic driver ( 34350694 ) or the touch ic controller ( BCM5976 ??
Please help, thanks.
Old 05-01-2016, 13:23   #5702 (permalink)
Member: 2437111
hello good day, have a hiphone 5 with icloud locked, it is in the white screen, is to return to the idle screen mode?
Old 05-02-2016, 10:13   #5703 (permalink)
Member: 2567262
Thanks Meter: 4
How do i fix an iphone 5 from looping and keep rebooting
Old 05-06-2016, 10:00   #5704 (permalink)
Ouch samnang's Avatar
Member: 1305293
Thanks Meter: 271
iPhone 6 direct short how solution ?
Thank
Old 05-07-2016, 12:42   #5705 (permalink)
Member: 1150131
Sonork: yong89
Thanks Meter: 2
i have a iphone 5 out apple logo n restart.....pls help....
Old 05-07-2016, 13:01   #5706 (permalink)
Member: 218667
Thanks Meter: 19
Iphone 5c not work home
I have iphone 5c with not working home.I change all flex and boton.The problem is in pcb.Some help please ¿?
Thanks
Old 05-07-2016, 14:38   #5707 (permalink)
Member: 2240742
Thanks Meter: 76
Thanks
check FL5 ,C176 and DZ15
Old 05-07-2016, 21:14   #5708 (permalink)
Member: 2192016
I have iphone 6 proximity sensor not working i change 2 flex... pls help
Old 05-08-2016, 17:58   #5709 (permalink)
Member: 1675922
Thanks Meter: 61
I have Ipad2, A1395, EMC2415 with icloud.
Any of you know if it possible to bypass it by changing serial number from the NAND memory?
thx
Old 05-09-2016, 18:56   #5710 (permalink)
Member: 2570695
iPhone 5 microphone does not work at all. I have tried on ear, speakerphone and headphones with no luck. I even replaced the charge port assembly. What could be my issue?
Old 05-10-2016, 05:16   #5711 (permalink)
Member: 2570836
Check connector on board first, may be fault there, if you will find no fault there then
Try to give heat or change Audio ic
Old 05-14-2016, 22:09   #5712 (permalink)
Member: 1096434
iphone 4 and 4s and 5
hi
i have some iphone 4 and 4s and 5 they have ic audio and ic micro.
i need solution.
best regard
Old 05-16-2016, 21:05   #5713 (permalink)
Member: 2259454
Hello ! Is there a Universal Hardware Solution for unlock all Apple Models from Icloud ?
I here there is a chip or something that needed to be change for a unlocked.
The solution should be fast, cheapest way to unlock and when possible in Austria / Europe near be.
i know in china is this possible but i dont ship to china
Old 05-17-2016, 16:39   #5714 (permalink)
Member: 1001420
Iphone 5s all time searching modem blank.
After updating to v.9.3.2 error 50 appears on iTunes.
Any suggestion?
Old 05-18-2016, 07:24   #5715 (permalink)
Member: 1077275
Thanks Meter: 14
Red face Iphone 4S low wifi after reassamble
I replaced LCD/Touch panel of my IPHONE 4s , after this my WI-Fi not works proper , shows low range .
Kindly help me to resolve this .
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.97621 seconds with 10 queries
