10-05-2016, 01:35 | #5821 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2632993 Status: Offline Thanks Meter: 0 | Any suggestions please! Thank you |
10-05-2016, 15:38 | #5822 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2625076 Status: Offline Thanks Meter: 4 | Hi everone, My problem is that: Iphone6 after water damage, no display but backlight works. Itunes find and recognize iphone. Seems to be ok... no long scrue problem, caps and resistors neer to display port are ok. Where to look for? Secondly; is where display driver or other ic respond for display on? |
10-09-2016, 14:41 | #5825 (permalink) |
Freak Poster Join Date: Jun 2016 Location: India
Member: 2585338 Status: Offline Thanks Meter: 43 | Hello, I have an ipad 3 3G now its in dead condition before it work good but after back case replacement its not powering on , there is a component with apple logo that component getting over heating i think it is power IC. please suggest any one??????????!!!!!!!!! |
10-10-2016, 10:40 | #5826 (permalink) |
Crazy Poster Join Date: Mar 2010
Member: 1264415 Status: Offline Thanks Meter: 3 | hello i've an ipad air 2 that i cant get into recovery to do a restore. It seems the touch id is stopping me from getting it into dfu mode. i've had the icloud removed online and want to restore it. is the touch id stopping me or could be be a faulty home button.......i'm thinking of replacing the home button to get to recovery then putting the old one back... |
10-10-2016, 18:05 | #5827 (permalink) |
Member: 2635308 Status: Offline Thanks Meter: 0 | My iPhone 5S shows the low battery icon, when I plug the charger in nothing changes (no lighting bolt to show it's charging) and the phone doesn't power up. When I unplug the charging cable the 'plug cable in' icon shows at the bottom of the screen. The charger and cable work perfectly on another iPhone and I have also tried another Apple cable and charger on this iPhone. Any help greatly appreciated! Thanks. |
10-20-2016, 05:16 | #5831 (permalink) |
Insane Poster Join Date: Aug 2015 Location: Middle-Europe Age: 39
Member: 2442957 Status: Offline Thanks Meter: 5 | Hello can help me please, i have an 5C and 6, the problem was not charging, i did replace a new U2 / U1700 ic, now the phone shows its charge but not increase percentage. Im not a starter, i made this skill many times, but now i dont know what to do...On logic board not damaged, already check. Battery and dock connector changed, same problem. Many thanks! |
10-20-2016, 06:21 | #5832 (permalink) | |
Member: 2639048 Status: Offline Thanks Meter: 2 | Quote:
sorry can't post full link thats a link code i have other problem my iphone 6s no show imei using *06# but at "about menu" show all imei baseband etc" only using *06# need help thanks.. | |
The Following User Says Thank You to mezchro For This Useful Post: |
10-21-2016, 05:39 | #5834 (permalink) | |
Member: 2442957 Status: Offline Thanks Meter: 5 | Quote:
Your problem, i think its around baseband ic (reheat 300°C circle move with solder flux 1 minute) | |
The Following User Says Thank You to THoMZoNE For This Useful Post: |
10-21-2016, 07:11 | #5835 (permalink) | |
but i will try it. thanks | |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
