02-02-2017, 14:02 | #5986 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2663260 Status: Offline Thanks Meter: 0 | So do you have any solution for this one? Or point me what should I look at? Thanks in advance, Adrian. |
02-02-2017, 14:52 | #5988 (permalink) |
Junior Member Join Date: Sep 2016
Member: 2628637 Status: Offline Thanks Meter: 0 | my ip box v2 is dead? its blinked the process led and my pc find dout him what can i do ??? ican dount send the link but on youtube can you search this : Problem with the ipbox V2 User Repair-Labor |
02-02-2017, 15:13 | #5989 (permalink) | |
Freak Poster Join Date: Jul 2012
Member: 1784601 Status: Offline Thanks Meter: 21 | Quote:
Inviato dal mio ASUS_Z00AD utilizzando Tapatalk | |
02-02-2017, 16:47 | #5990 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2672199 Status: Offline Thanks Meter: 0 | A friend have an iphone 5s that was with a bad battery ( turning off with 80%) He was using it on charger and suddently the phone turned off and only showed apple logo and then reboots to apple logo again . I tried two differents batteries and had same results. When i try to turn it on or when i try to plug a charger on it. Do you guys think its a u2 ic problem? since its the power manager ic, maybe the bad battery damaged it |
02-02-2017, 16:51 | #5991 (permalink) | |
02-03-2017, 12:11 | #5992 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2637452 Status: Offline Thanks Meter: 0 | iphone 5 water damage..after clean with solution its was working ..but now it is complete dead..can anybody tell me the solution ..what things need to be check ...its show 680ohms resistance on same polarity on battery terminal and 430ohms on opposite polarity..please any expert give advice.. |
02-03-2017, 12:19 | #5993 (permalink) |
Member: 2625076 Status: Offline Thanks Meter: 4 | PP_VCC_MAIN problem hello, anybody help? iPhone 6s has been droped down on the floor. Screen and home button are scrap. The phone starts with no backlight and image in service mode (iTunes). Both video rails /video & backlight/ seem to be ok. All caps look fine. However low voltage on the PP_LCM rail gives food for thought. / ;-) : PP_LCM_BL_CAT1_CONN: 0.0V PP_LCM_BL_CAT2_CONN: 0.0V PP_LCM_BL_ANODE_CONN: 3.96V Those measurements led me that the damage should look much lower and I go much lower than, to PP_VCC_Main rail. Here my measurements: Power rails: ground-ok PP5V0_USB: 4.86V PP_BAT_VCC: 3.94V E75 rails: TRISTAR_DP1_CONN_P and _N: 0.001V _DP2_CONN_P and _N: 0.0V _ACC1: 2.71V _ACC2: 0.0V TRISTAR_CONN_DETECT_L generates 0.04V on the other hand PP1V8 & PP1V8_ALWAYS they have 1.8V Question smarter than me: what should be the appropriate voltage on PP_VCC_MAIN and PP_BAT_VCC and PP5V0_USB in iPhone 6s? thanks and regards, |
02-11-2017, 15:10 | #5999 (permalink) |
Junior Member Join Date: Sep 2013 Location: Croatia
Member: 2032463 Status: Offline Thanks Meter: 0 | Hi, everyone. I have a iphone 5c where I changed the chip u2 because cell phone would not start, then the phone started working and worked a little less than a year precisely until now, in fact he is still working but I have a problem with time. I tried to put manually and automatically, but after one day stopped again and walked random changes. I tried it reset to factory settings but does not help, I also tried to change the battery but even this does not help. I wonder whether there is a possibility that the problem again in this chip that I changed (u2), if he has anything to do with the time on the iPhone? Thank you. : D |
02-11-2017, 15:15 | #6000 (permalink) | |
The Following User Says Thank You to mariodepomi For This Useful Post: |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
