12-26-2018, 12:53 | #6453 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 225506 Status: Offline Thanks Meter: 31 | good morning to all plase i have iphone 7plus camera non work frontale and posterior the program open good with black screen in to camera all fonction for program work zoom....., that always black screen i test fl connector and filter 4 pin not have any problem also recovery with dfu not work please any suggest please thanks |
12-29-2018, 09:18 | #6454 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2505867 Status: Offline Thanks Meter: 0 | iphone 6plus error 2006 i have iphone 6plus showing error 2006 how to solve this help me mobile initial condition is batree ribbin broken i have changed batree and restor it. it shows 2006 |
12-29-2018, 15:31 | #6455 (permalink) | |
Junior Member Join Date: Apr 2016
Member: 2556868 Status: Offline Thanks Meter: 0 | Quote:
Check this line in diode mode 507 and voltage 2.9V. | |
12-31-2018, 02:44 | #6457 (permalink) |
Junior Member Join Date: Dec 2018
Member: 2885898 Status: Offline Thanks Meter: 1 | iPhone 7 Plus rebooting when idle I recently replaced a screen for a customer for a iPhone 7 Plus. When you are actively using the phone it’s fine, but when you let it set idle it reboots. Never had this issue in the past. I ordered another screen and a battery for testing, also a DFU restore may cure it. One thing to note is that when I opened the case there was dirt inside. I asked her about it and she did say she dropped it in water and had to rice it dry. Odd that it only does it when idle. Any other suggestions that may be causing this isolated issue? |
The Following User Says Thank You to flyzapper For This Useful Post: |
01-02-2019, 12:11 | #6458 (permalink) | |
01-06-2019, 19:53 | #6460 (permalink) |
Insane Poster Join Date: Apr 2009 Location: Cyprus
Member: 1009459 Status: Offline Sonork: panicos 4568753257 Thanks Meter: 27 | Hi I have an iPhone 5se I change the battery And after that the phone stuck on 1% and reboots all time I put the old one but it’s the same help please Thankss |
01-17-2019, 05:28 | #6461 (permalink) |
Freak Poster Join Date: Mar 2010 Location: Three stars and a sun
Member: 1261122 Status: Offline Thanks Meter: 21 | hi can you help me out with this 6s plus restart for 3 minutes or 5 minutes when using. |
The Following User Says Thank You to highlights2010 For This Useful Post: |
01-18-2019, 19:47 | #6463 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2386121 Status: Offline Thanks Meter: 0 | guys, having issue within 2 of these model. iPad random reboot. Stuck iTunes error 6,9,4013. Change a brand new Nand with programmed original serial but still same. Any idea ? iPad Pro 10.5 A1701 random reboot. Error 6,9,4013. |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
I need DVD player hardware and software solution site | ..::MOBILES::.. | GSM Mobile Links | 0 | 04-05-2009 15:49 |
O2 Hardware and Software solutions | Eagle7 | Various | 2 | 04-14-2006 12:47 |
