Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-28-2019, 09:52   #6481 (permalink)
Member: 2515171
iphone 5s
iphone 5s error 4013
Old 02-28-2019, 11:11   #6482 (permalink)
Member: 634464
Thanks Meter: 3
hello sir some iphone 6 just shows searching and no service help me please
The Following User Says Thank You to razmohammad For This Useful Post:
Old 03-06-2019, 11:17   #6483 (permalink)
Member: 2807291
Need help please. I flash an iPhone 6s with 3 utools, it is stuck on 19% and says unable to restore idevice (-2). Help me please
Old 03-09-2019, 13:18   #6484 (permalink)
Member: 215177
Thanks Meter: 19
flash it with itunes then tell me the error and progress line then i will tell you the solution
Old 03-10-2019, 07:04   #6485 (permalink)
aravindanav's Avatar
Member: 1587303
Thanks Meter: 42
How to Activate iPhone X At &T that Needs Zip and Social Security Number SSN
Old 03-12-2019, 08:02   #6486 (permalink)
Member: 2556868
First you need a AT&T Sim Card.
Put in AT&T Sim card in
Connect with itunes
first 00000
2nd 0000
after this disconnect and re add sim card. Good Luck
Old 03-12-2019, 08:03   #6487 (permalink)
Member: 2556868
Most likely NAND but test u2 output.
Old 03-12-2019, 08:06   #6488 (permalink)
Member: 2556868
*#06# do you get IMEI?
If yes then it might be antenna
if not Then Test BBPMIC output next to baseband ,should be around 1.2 volt. If current is good , then you need a reball of baseband if not its BBPMIC. Good luck
Old 03-12-2019, 08:07   #6489 (permalink)
Member: 2556868
Try a new battery and Charging port also try flashing bare with just battery and charging connector. Good Luck
Old 03-19-2019, 13:47   #6490 (permalink)
Member: 2032636
I have an iphone x, unfortunately imei hss gone, there is no imei in the phone, any one can help me to find solutions
Sent from my Redmi Note 5 using Tapatalk
Old 03-21-2019, 01:01   #6491 (permalink)
Member: 2898557
Sonork: 100.1682343
my iphone 6 plus doesn't turn on the both camera i tried some solution like jumper but still no luck
Old 03-22-2019, 00:51   #6492 (permalink)
Member: 2532158
Thanks Meter: 8
2 x Iphone SE Signal Problems, One with Shorted Chip - U_ANTPAC_RF (RF1346)
Ok so I have 2 Iphone SE's with similar problems:
Pink one -> Shorted Chip - U_ANTPAC_RF (RF1346).
So this came shorted causing tristar to not function properly as they both run off the 3V line, removing this chip fixed the other problems.
Now the phone appears to work normally but just very occasionally drops from 4g to 3g. I've only tested around my house.
First thing is, there is no info anywhere about this chip, and is not available to buy! Of course I can buy an Icloud board and remove it but does anyone know where it can be bought, is it under another name???
Also do I really need to replace it, if I give it back is it going to be un-noticable or will there be many occasions of signal problems. As far as I can see it is making a connection to the top antenna??
Second Black SE : Signal is always there with at least 2 bars in house but no 3G or 4g and usually won't ring out unless outside.... so why are there 2 bars??
It had some minor liquid damage that I took photos of, I will add soon but I checked all continuity to antennaes and only relevent area was this antenna switch -> U_SWUANT_RF which on the pink SE is missing and has the 0 ohm resister bypassing it. I tried this but no difference! It is covered in resin anyway so doesnt look affected.
No shorts found anywhere.
So any ideas on these, also any explanations how all the antennas work would be great as no info anywhere? Or any info generally about how modern smart phones use the antennas?? I heard there are 3 antennas?
Both have been tested in good chassis. I believe the pink just needs that chip but can it just be left?
On my own Iphone 5S, dis-connecting the bottom antenna on the charge port appears to make no difference so what is if for?
Many thanks.
Old 03-22-2019, 17:41   #6493 (permalink)
Member: 2532158
Thanks Meter: 8
I have photos but it always says failed to upload??
Any ideas?
Size is smaller than it says....
Old 03-26-2019, 11:59   #6494 (permalink)
Member: 1489453
My iphone 7 imei and imeid is missing , any help?
Originally Posted by mobitech servic View Post
u can post ur problems here
Old 04-06-2019, 08:42   #6495 (permalink)
Member: 2504391
hi sir,
i have Iphone 6 ios 12.2 latest version
any way of the jailbreak
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.26897 seconds with 10 queries
