Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 04-17-2019, 18:06   #6496 (permalink)
Member: 2888158
iphone 8 plus bented not charging
hello please I need help I have a iphone 8 plus than has bent mother board on the sim card tray side it is not charging I replace tristar when i connect to power supply it show 0.4A then it start booting then it go up to 1.8A and turn off BB_K get really hot after that
Old 04-23-2019, 21:57   #6497 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 477
Originally Posted by razmohammad View Post
hello sir some iphone 6 just shows searching and no service help me please
Baseband ic need to be reballed and broken traces under the ic need to be reconnected with jumper wires
Old 04-23-2019, 21:59   #6498 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 477
Originally Posted by TELEFOONMASTER View Post
Most likely NAND but test u2 output.
True and could also be longscrew damage
Old 04-23-2019, 22:05   #6499 (permalink)
HDccam's Avatar
Member: 1732818
Thanks Meter: 477
Originally Posted by AkeebFahiz View Post
apple ipad a1430 restore error -1 itunes error solution plese.
Baseband ic problem. You can can make the ipad wifi only by doing the icloud ipad 3 bypass. Not sure if the activation still will be accepted. Since that has changed since iOS 11
Old 05-24-2019, 13:03   #6500 (permalink)
Member: 2260409
Thanks Meter: 18
Hello
i need help
i have iphone 6 and iphone 7 both have same probleme like a virus
not charging when power on
whan plug charger in powered off it just go on and all time 1%
and everytime in search for network
thanks in ADVENVCE
Old 06-07-2019, 19:43   #6501 (permalink)
Member: 2500101
hi i have iphone 7
before has weak signal but now no imei no modem
i changed bb pmu i removed baseband and reballed
no short.....
but problem still has....
Old 06-30-2019, 02:39   #6502 (permalink)
Member: 1214267
Sonork: riyasibrahim86
how to identify iphone x battery +ve line now battery is dowen how to boost battery?
Old 06-30-2019, 14:38   #6503 (permalink)
kissssna's Avatar
Member: 810694
Thanks Meter: 30
iPhone X
dropped and when tried to restore no error but was unable to activate
getting this error in iTunes
"iphone could not be activated because the activation information could not be obtained from device"
any solution please help
Old 07-07-2019, 02:17   #6504 (permalink)
Member: 2889269
Arrow icloud
Originally Posted by mobitech servic View Post
u can post ur problems here
icloud 6s and some petty and i wA
Old 07-17-2019, 09:44   #6505 (permalink)
Member: 2903495
my iphone 7 plus shutdown when taking picture
Old 07-19-2019, 15:20   #6506 (permalink)
Member: 2110006
hey sir i have a iphone 6s[/I][/B][/B][/B][/COLOR] it was water damge but after cleaning the bord its turning on but its stuck on apple logo any solution please tnx in advance /////
Old 07-21-2019, 00:28   #6507 (permalink)
Member: 310418
Thanks Meter: 9
unlock pin code!
need Your help guys, samsung galaxy s10+, cant lose data ! there is pin code, what can i do ?
Old 07-22-2019, 20:34   #6508 (permalink)
Member: 716133
Thanks Meter: 38
iphone 7+ problam
*******r bring smashed phone very bad i buy new lcd new battery phone swich off but very worm battery and motherboard any can i post for fix thanks
Old 09-11-2019, 12:14   #6509 (permalink)
Member: 2926350
I have IPhone 5 dead.
I tested the PP_BATT_VCC and PP_VCC_MAIN and they aren't shorted to ground. But while inspecting the board i found the following:
1- line HS3_CONN is shorted to ground.
2- Q8's Drain and Source are shorted.
Can any line of those stop the phone from charging and booting
All Blackberry Hardware and Software Solution youssef01 BlackBerry (RIM) 34 11-01-2012 17:31
I need DVD player hardware and software solution site ..::MOBILES::.. GSM Mobile Links 0 04-05-2009 15:49
O2 Hardware and Software solutions Eagle7 Various 2 04-14-2006 12:47
Page generated in 0.39930 seconds with 9 queries
