Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-10-2010, 08:27   #1 (permalink)
Member: 1104730
{iPhone, iPad} Components, Schematics, Diagrams etc....
Apple Iphone 3G and 3GS IC Parts Datasheets(Component Schematic Diagram and Info)
For Hardware Pro's and Advance troubleshooter's Guide
3G
3GS
SST SST25VF080B 1 MB SERIAL FLASH
http://www.alldatasheet.com/datashee...T25VF080B.html
Samsung ARM-based CPU (markings: 339S0036 ARM EMC567DB 819 8900B N182F0A3 0825 7511.101 ZPD8163Y)
with DDR SDRAM Samsung
http://datasheet.octopart.com/K4X1G1...eet-472067.pdf
ST MICROELECTRONICS LIS331 DL ACCELEROMETER
http://datasheetz.com/ST/13951/13951.html
INFINEON SMP3i SMARTi POWER MANAGEMENT IC
http://www.infineon.com/cms/en/produ...19ebec03f05327
Skyworks SKY77340 Power Amp. Module (824-915 MHz Power Amplifier Module Quad)
http://www.datasheetpro.com/425257_d...datasheet.html
Infineon PMB 6952 UMTS Transciever
http://infineon.com/cms/en/product/c...12ab6ac4b80611
Triquint TQM676031 WCDMA/HSUPA power amp
An integrated 3-V linear UMTS Band 1 power amplifier (PA),
duplexer and transmit filter module, with output power detector.
It supports HSUPA operation with transmission data-rates up to 10 Mbits/s.
http://www.triquint.com/docs/o/TQM676021/tqm676021.pdf
Triquint TQM666032 WCDMA/HSUPA power amp
Similar like TQM676031, but for Band 2 operation.
http://www.triquint.com/docs/o/TQM666022/tqm666022.pdf
Triquint TQM616035 WCDMA/HSUPA power amp
WCDMA/HSUPA PA-duplexer module for Band 5 and 6.
datasheet unavailable
Numonyx PF38F3050M0Y0CE 16 MB NOR Flash - 8 MB Pseudo-SRAM
http://www.numonyx.com/Documents/Mar...ORwireless.pdf
Infinieon Digital Baseband Processor
NXP Power management
http://people.openmoko.org/tony_tu/G...50633DS_02.pdf
Linear Technology LTC4088-2 Battery charger/USB controller
http://cds.linear.com/docs/Datasheet/40881fb.pdf
Infineon PMB2525 Hammerhead II GPS
http://www.datasheetdir.com/PMB2525+GPS
Wolfson WM6180C Audio Codec
http://www.wolfsonmicro.com/productListings/codecs
Broadcom BCM5974 Touchscreen controller
no datasheets available
NATIONAL SEMICONDUCTOR LM2512AA DISPLAY INTERFACE
http://www.national.com/ds/LM/LM2512A.pdf
Toshiba TH58G6D1DTG80 8GB Flash (8GB model!)
Marvell 88W8686 WiFi
http://www.pdf-search-engine.com/88w8686-pdf.html
CSR BlueCore6-ROM Bluetooth
http://downloads.openmoko.org/develo...2520Issue1.pdf
Old 05-02-2010, 09:49   #2 (permalink)
ATUSH's Avatar
Member: 214499
Sonork: 100.1591348
Thumbs up iphone hardware informations
this is hardware info for iphone
Old 05-02-2010, 09:51   #3 (permalink)
ATUSH's Avatar
Member: 214499
Sonork: 100.1591348
some more iphone pbc info.......
Old 05-02-2010, 09:53   #4 (permalink)
ATUSH's Avatar
Member: 214499
Sonork: 100.1591348
iphone 3gs main board......
Old 05-02-2010, 10:07   #5 (permalink)
ATUSH's Avatar
Member: 214499
Sonork: 100.1591348
iphone 3gs main board informations it is usefull for hardware
Old 05-02-2010, 10:17   #6 (permalink)
ATUSH's Avatar
Member: 214499
Sonork: 100.1591348
this is iphone 3gs main board from the bottom hardware informations
Old 05-04-2010, 08:22   #7 (permalink)
GSMman187's Avatar
Member: 917893
Sonork: 100.1584763
*** 3G & 3GS DIGITIZER - How to tell the difference ;) ***
*** 3G & 3GS DIGITIZER - How to tell the difference ***
enjoy..
br.
Old 05-08-2010, 01:49   #8 (permalink)
Mad Scientist's Avatar
Member: 99827
iPad Motherboard
Old 07-01-2010, 13:51   #9 (permalink)
Moderator
.::iRizwan::.'s Avatar
Member: 79937
Sonork: 100.84313
iPhone 4 PCB Front
iPhone 4 PCB Back
Enjoy
Old 10-30-2010, 20:42   #10 (permalink)
Crazy Poster
Member: 1318122
3G Power management IC user manual link:
https://people.openmoko.org/tony_tu/...F50633UM_6.pdf
Hope this helps someone.
The Following 5 Users Say Thank You to jseraphim For This Useful Post:
Old 11-15-2010, 19:56   #11 (permalink)
Crazy Poster
Member: 1318122
Link to power management controller still works for me.
Try http instead of https, or you may need to allow security certificate from untrusted site -
http://people.openmoko.org/tony_tu/G...F50633UM_6.pdf
It works as http: with Firefox, may be more a a problem with Internet Explorer.
The Following 3 Users Say Thank You to jseraphim For This Useful Post:
Old 10-24-2011, 00:50   #12 (permalink)
Moderator
Member: 79937
Sonork: 100.84313
iPhone 4s PCB Front
iPhone 4s PCB Back
Enjoy
The Following 5 Users Say Thank You to .::iRizwan::. For This Useful Post:
Old 10-26-2011, 19:48   #13 (permalink)
Moderator
Wites OM Tesla's Avatar
Member: 1017374
Lightbulb iPhone 3GS Light Coil Available in...
By wites13 at 2011-10-26
Regards
The Following 4 Users Say Thank You to Wites OM Tesla For This Useful Post:
Old 10-28-2011, 10:12   #14 (permalink)
Moderator
Member: 1017374
Lightbulb iPhone 3GS Voltage Checking!
This Check is when phone is power on,if phone have problems dead or powering on you check this voltages.
By wites13 at 2011-10-28
Save image and zoom in.
Regards
The Following 8 Users Say Thank You to Wites OM Tesla For This Useful Post:
Old 11-01-2011, 18:10   #15 (permalink)
Moderator
Member: 1017374
Lightbulb iPhone 3G Voltage Checking!
Same as 3GS when not power on etc.
http://imageshack.us/a/img228/1693/i...gechecking.jpg
Your thanks give me boost.
Thanks Regards.
I have Wintesla PKD-1 dongle schematic and activation file Gsmhq Nokia Hardware & Hardware-Repair Area 3 08-20-2004 10:11
Fbus/Mbus schematics? Blunty Nokia Hardware & Hardware-Repair Area 3 06-03-2001 01:59
Si-prog schematics, some one help AMTX99 Nokia Hardware & Hardware-Repair Area 4 09-21-2000 23:21
looking schematic for nokia5161 battery with vibra dofie Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-13-2000 22:48
GSM Links Datacable Schematic Logo Ringtone GM GSM Mobile Links 0 01-30-2000 13:52
Page generated in 0.47038 seconds with 12 queries
