Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-14-2018, 07:36   #331 (permalink)
Member: 2535439
Thanks Meter: 14
Originally Posted by mahbubalfa View Post
iphone 7 charging solution.
iphone 7 light solution.
iphone 7 audio solution
iphone 7 no power solution.
iphone 7 WiFi solution
Bro i have big problem my own iphon6s giving me error 3 bro plz hlp me and how can i contact with u any phone no give bro plz
Sent from my SM-J700F using Tapatalk
Old 01-16-2018, 06:24   #332 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
iPhone x LCD replacement.
https://www.youtube.com/watch?v=rDi4q11giuY&t=104s
iPhone x battery replacement.
https://www.youtube.com/watch?v=N2W6XwqCXnE&t=6s
iPhone 8 LCD & battery replacement.
https://www.youtube.com/watch?v=1eexQtAMBxU&t=29s
Old 01-16-2018, 06:36   #333 (permalink)
mahbubalfa's Avatar
Member: 1003058
Originally Posted by surajnad View Post
i phone 6 flash light not work help me i change on off flex but same i want flash light ways thank you
Bro.try this solution.
http://forum.gsmhosting.com/vbb/12497591-post33.html
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 01-17-2018, 15:36   #334 (permalink)
Member: 92260
Thanks Meter: 843
Iphone 7 home Button solution.
First, what is this solution supposed to fix exactly?
Second, what exactly have you done in this pic, looks like the flex was scratched/cleaned up??
Any solution for non-original non-synced replacement touch button?
Thanks.
Old 01-17-2018, 18:00   #335 (permalink)
Member: 2425737
Thanks Meter: 7
hi iphone x error 4013 solution please
Old 01-18-2018, 06:28   #336 (permalink)
mahbubalfa's Avatar
Member: 1003058
Try these steps:
Install the latest version of iTunes.
Force your device to restart:
On an iPhone X, iPhone 8, or iPhone 8 Plus: Press and quickly release the Volume Up button. Press and quickly release the Volume Down button. Then, press and hold the Side button until you see the Apple logo.
On an iPhone 7 or iPhone 7 Plus, press and hold both the Side and Volume Down buttons for at least 10 seconds, until you see the Apple logo.
On iPhone 6s and earlier, iPad, or iPod touch, press and hold both the Home and Top (or Side) buttons for at least 10 seconds, until you see the Apple logo.
Connect your device to your computer using a USB cable.
When iTunes asks you to update or restore, click Update (not Restore) to reinstall iOS and keep your personal data.
If you still need help, try these steps
If you can update, but your device starts up in recovery mode, follow the steps above again. On step 4, choose Restore instead of Update. After the restore completes, you need to set up your device from a backup.
If you continue to see an error during the update:
Check for updates to your Mac or PC. If you restart your computer for an update, check for updates again after you restart.
Try to restore your device using another USB cable.
Try to restore your device on another computer.
Old 01-19-2018, 10:46   #337 (permalink)
Member: 2795472
iphone 6plus display not work
iphone 6plus display not work show three purple vertical lines plz hlp
Old 01-22-2018, 04:34   #338 (permalink)
Member: 689942
Thanks Meter: 312
Friend, first of all congratulations for the solutions posted here.
I have an iphone 7, which works everything normally except for the fact that I consume the battery very fast without using it and if I do not load it, soon when the battery is over, it will not charge anymore.
I changed the battery and already changed the charging connector and it did not work.
Can it be the U2 controller?
Old 01-23-2018, 19:02   #339 (permalink)
Member: 2425737
Thanks Meter: 7
Hi IPhonex error 4013 solution please
Envoyé de mon iPhone en utilisant Tapatalk
Old 01-27-2018, 21:07   #340 (permalink)
Member: 1847332
Check FL2400 ... I hope I have helped.
Old 01-27-2018, 21:18   #341 (permalink)
Member: 1847332
Originally Posted by haku89 View Post
hi.. i got problem on iphone 5se.. the percentage keep 1% not increase.. plizz help me
Old 02-05-2018, 19:03   #342 (permalink)
Member: 1561598
Chang u2 ic 100% solution
Old 02-05-2018, 19:13   #343 (permalink)
Crazy Poster
Member: 2161862
Thanks Meter: 7
go step by step
1 change charging flex
2 change battery
3 rehot u2
4 replace u2
do one by one and check hit thnx when done
Sent from my iPhone using Tapatalk
Old 02-08-2018, 11:21   #344 (permalink)
Member: 557167
Sonork: 100.1626163
Thanks Meter: 12
hi bro MAHBUBALFA
I have an iphone 7 with restart on apple logo..
restore done with 3utool,after complete restoring same,RESTART ON APPLE LOGO,
after that finely i changed U2 ic and also rehot AUDIO CODEC..
plzz give me any tested solution
Old 02-10-2018, 22:26   #345 (permalink)
Member: 2583697
Sonork: 100.1677424
Thanks Meter: 21
Hahaha
If all problems solutions is from ic’s...?
Then there is no need for other components...
Page generated in 0.29344 seconds with 8 queries
