07-16-2018, 09:24 | #392 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Madrid
Member: 1898289 Status: Offline Thanks Meter: 39 | Should be NAND communication issue, you must remove it and check if missing/break pad and fix that track. Maybe luckily just reball the NAND is enough. |
The Following User Says Thank You to mandango For This Useful Post: |
07-16-2018, 09:27 | #393 (permalink) |
Member: 1898289 Status: Offline Thanks Meter: 39 | BB IC, do a rehot to check in advance. If works for a while you need to reball for works for over time, reflow is not final solution. If doesn't work as well maybe need to redo a track |
07-16-2018, 09:57 | #394 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: UNITED KINGDOM Age: 44
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 339 | Quote:
best regard karim | |
09-03-2018, 17:35 | #395 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1687301 Status: Offline Sonork: 5456 Thanks Meter: 0 | hello . i have a iphone 6 plus . battery percentage jumps when i connect cable and percentage change again when i reconnect the cable again . when i connect the phone to pc its restart and stuck on logo untill it is connected to pc . it will turn on if disconnect from pc . i changed u2 ic . i did jumper . i did reset setting . i dont know what to do next . please help me . sorry for my english ... |
09-09-2018, 12:42 | #397 (permalink) | |
Junior Member Join Date: Feb 2008
Member: 697893 Status: Offline Thanks Meter: 11 | Quote:
VBAT TO VBAT NTC TO NTC GND TO GND | |
09-09-2018, 12:43 | #398 (permalink) | |
10-20-2018, 12:31 | #403 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2420684 Status: Offline Thanks Meter: 2 | Hello Guys! I have a problem with iphone 6s that can't connect in wireless 2.4ghz. The phone finds the network but it can't connect and says incorrect pasword. With 5Ghz network the connection is ok. Does anybody has had this problem before, i should change the wifi module and unbind NAND. THanks |
10-27-2018, 18:46 | #405 (permalink) |
Freak Poster Join Date: May 2005 Location: Senica Age: 47
Member: 148476 Status: Offline Thanks Meter: 27 | HI, all i have iphone 6s and when charge, phone not have signal or low signal.. Without charging is ok.. Second problem: Audio button +- and camera microphone not working.. . I change all flex and nothing any idea ? THNX |
