Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-22-2018, 06:15   #1 (permalink)
Member: 1276771
Thanks Meter: 31
iPhone X back glass replacement
Hi
Expert member need your advice.
what is the best way to remove Iphone X back glass.
As i followed youtube videos it took me too long to do that especially back camera lens removal.
any tips and tricks for this.
thanks.
The Following User Says Thank You to javeed_aminy For This Useful Post:
Old 07-24-2018, 09:33   #2 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 4,923
Originally Posted by javeed_aminy View Post
Hi
thanks.
First you have to remove all parts from housing.
Stick housing to your desk, use your hot air gun to warm up the broken glass so glue will be loose, at the same time use a razor tool blade (see pic) to remove broken glass. Careful about edge, there is a tiny plastic/rubber border which is attached with housing, don't damage it, otherwise it will look ugly after replace new glass.
Once you done with broken glass, remove camera glass with it metal body (see pic) from housing. You have to use razor tool blade or some other blade to cut that welding joint (see pic)
After replace new glass, put back that camera glass with metal body by glue.
And you are done. It took me 2/3 hours to finish that all process so I charged each customer 130$-160$
Next time I will try to make a video for you guys.
Thank you
The Following 6 Users Say Thank You to tkowsar For This Useful Post:
Old 08-16-2018, 17:15   #3 (permalink)
Member: 2511554
Sonork: 100.1671270
Thanks Meter: 8
Thank you
Will phone be sealed properly?
The Following User Says Thank You to OfficialEU For This Useful Post:
Old 08-29-2018, 11:57   #4 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 4,923
Everything will be look usual, depends on you skill but if you talking about waterproof facility, it will not.
The Following 2 Users Say Thank You to tkowsar For This Useful Post:
Page generated in 0.31085 seconds with 8 queries
