07-15-2019, 06:54 | #1 (permalink) |
Junior Member Join Date: Apr 2019 Location: S
Member: 2904736 Status: Offline Thanks Meter: 6 | iPad mini 2 charging problem I have a problem with mini 2. He doesn't charging when is turned on, when is turned on I get 1% battery and then put usb and get e.g 30%, if I leave charger in ipad he is restart and again show 1% battery. Also charger is cold, so ipad probably doesn't "use" current. If I connect charger and then turn OFF ipad, charger get hot, that means that ipad "use" current. After 1 hour when turn ON ipad I get e.g 30% but if connect charger to ipad he is restart after one-two minute. So he want to charge only when is OFF. Also when is charger connected battery percentage drop very quickly. I tryed to change tristar but I get same problem. Thank you in advance. |
