12-12-2016, 16:58 | #1 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1099160 Status: Offline Sonork: akash Thanks Meter: 3 | iphone7 home button solution any body have solution? |
The Following User Says Thank You to akashgerais For This Useful Post: |
12-13-2016, 16:57 | #4 (permalink) |
Freak Poster Join Date: Dec 2014 Location: PCB
Member: 2320407 Status: Offline Thanks Meter: 88 | your case is (iPhone 7 no home button) did you try your iphone 7 home button on other phone ? did you try other home button from other iphone 7 to your OWN iphone 7? |
The Following User Says Thank You to ctccellulaire For This Useful Post: |
05-27-2017, 12:47 | #12 (permalink) |
Insane Poster Join Date: Nov 2006 Location: Sri Lanka
Member: 392792 Status: Offline Sonork: lasa_dal Thanks Meter: 8 | like iPhone 6 and 6s , 7 have no home button switch ,therefore the home key function is generated from fingerprint sensor . as we all know fingerprint sensor only works with the original phone which it comes with .. . still no solution for 7 home button |
05-27-2017, 13:23 | #13 (permalink) | |
Freak Poster Join Date: Jan 2014
Member: 2106911 Status: Offline Thanks Meter: 67 | Quote:
like NAND and BB and other stuff so you have to use exactly the same button so you have to check your voltage lines and check for missing connection and also if the button flex cable isn't cut . | |
05-27-2017, 17:21 | #15 (permalink) |
Junior Member Join Date: Dec 2009 Location: Netherlands, Gelderland
Member: 1190472 Status: Offline Thanks Meter: 9 | Had a same problem with a 6s. What i did could help you if you only want a clicking homebutton insteed of using assistivetouch on screen. After this touch-id is not working. Maby it works for a a iPhone 7 the same. I made a wire on the housing of the phone with crocodile clamp and on the otherside a needle. Then i removed the flex comming from the homebutton en put the needle on the contacts on the mainboard to find the pin that acts like homebutton function. (By the 6s it was the sixt pin on the left from above, phone in normal position to you). Then i made a wire from the clicker of the button to the flexconnector and solderd it to the cable. Now i have a working homebutton exept touch-id. Again dont know if this working for for a 7 but i think it will.. Last edited by rb0wag; 05-27-2017 at 17:22. Reason: Spelling |
The Following User Says Thank You to rb0wag For This Useful Post: |
