Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-14-2017, 10:41   #1 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
iPlhone 6 Plus Error 11
I got one iPhone 6 Plus with passcode. I try to restore it with itunes . It giving me error 11. I tried with Utool and it stuck at Updating Baseband. What i can do now .
I downloaded new firmware and tried again and again i download new itunes but still same.
i deleted everything from downloaded folder but no luck.
iPhone_5.5_10.3.2_14F89_Restore
iPhone_5.5_10.3.3_14G5047a_Restore
Old 06-15-2017, 19:27   #2 (permalink)
pengaturan's Avatar
Member: 842814
Sonork: 100.1610112
Thanks Meter: 276
Reballs baseband IC sir.
Old 06-21-2017, 10:32   #3 (permalink)
Member: 2494453
Thanks Meter: 200
Error 1 or -1
This may indicate a hardware issue with your device. Follow Trouble shooting security software issues, and restore your device on a different known-good computer. If the errors persist on another computer, the device may need service.
This device is not eligible for the requested build (Also sometimes displayed as an "error 3194").
The most useful tip is :
unplug and replug your iPhone;and try to use the back USB port.
Then, if the issue still exists after your try several times, it could be a baseband issue.
Or maybe it caused by following reasons:
1.Update to the latest version of iTunes.
2.Third-party security software or router security settings can also cause this issue.
3.Downgrading to a previous version of iOS is not supported. If you have installed software to perform unauthorized modifications to your iOS device, that software may have redirected connections to the update server (gs.apple.com) within the Hosts file. Uninstall the unauthorized modification software from the computer.
4.Edit out the "gs.apple.com" redirect from your hosts file, and then restart the computer for the host file changes to take affect.( For steps to edit the Hosts file)
5.Avoid using an older or modified .ipsw file. Try moving the current .ipsw file (see Advanced Steps > Rename, move, or delete the iOS software file (.ipsw) below for file locations), or try restoring in a new user to ensure that iTunes downloads a new .ipsw.
Check original post here: http://3utools.********.hk/2016/12/h...rror-1-in.html
Page generated in 0.13472 seconds with 9 queries
