06-28-2015, 20:56 | #1 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 408358 Status: Offline Thanks Meter: 42 | iTunes error 1 or -1 when restore iphone 5s 5c (SOLVED) PROBLEM: baseband IC / modem SOLUTION: remove PCB , and apply 300gr hot air for 10sec. ( if no work try 20-25sec) ... on baseband IC http://imgur.com/Phxlq9U IMAGE HERE !!! |
The Following 4 Users Say Thank You to dark2peu For This Useful Post: |
07-09-2015, 04:03 | #4 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2424878 Status: Offline Thanks Meter: 0 | Hi, please help!! I´m getting error 47. Could you please explain how should I apply hot on the HW? Can I use a Hair Dryer, or do i need something with more heat?? what is 300gr??? thanks! |
07-10-2015, 23:47 | #5 (permalink) | |
Insane Poster Join Date: Feb 2014
Member: 2136675 Status: Offline Thanks Meter: 0 | Quote:
Thanks ! | |
07-18-2015, 09:35 | #6 (permalink) |
Member: 2136675 Status: Offline Thanks Meter: 0 | Hi, If i will try rehotting the baseband IC and it will still not work, can i change it ? I see that parts are available on aliexpress or ebay so i can easily buy. It will need something to do apart from chaning it ? Thank you ! Please help me..is very important. |
07-30-2015, 19:21 | #10 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Germany
Member: 2289832 Status: Offline Thanks Meter: 48 | It is not always working. I received many devices with this problm just 3 out of 10 works if i rehot. it takes me almost 4 hours to reball baseband. But this is also not working always. Sometimes pads r removed so device not working anymore. |
04-20-2016, 08:30 | #13 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2525054 Status: Offline Thanks Meter: 0 | no speaker und Touch ID Hallo, I have reheat the chip for low signal by iPhone 5s. Now I have signal but I don't have speaker und Touch ID. What i have done wrong? To much heat for to long time? How can I repair this problem. I have 2 iPhone 5s with this issue |
04-20-2016, 20:02 | #14 (permalink) |
Junior Member Join Date: May 2006
Member: 277668 Status: Offline Thanks Meter: 1 | Hello, Thanks for this, I tried it but didn't work for me. I've also re-balled BB perfectly with no success. Could anyone point me in the direction of the BB PMU to test (5S) ??? Thanks |
04-20-2016, 22:35 | #15 (permalink) |
Freak Poster Join Date: Jan 2005 Location: iran Age: 41
Member: 103931 Status: Offline Thanks Meter: 31 | Have error 50 iphone 6 after change wifi module!!! tested phone after change wifi module imei not show and modem firmware is blank!! rehot BB same problem.changed it same.. Any *** idea. maybe replace new BB from other pcb? |
