Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-01-2012, 07:46   #1 (permalink)
rogerboogie's Avatar
Member: 103024
Mr Wites
hi bro i reallly apreciate your job and experience, good to have people who likes to investigate and develop solutions
i like too
recently i have a problem and have some doubts
i was reballing the audio compiler ic i was fixed about 5 or 6 pieces by this method
recently i reball the ic , i have to add 3 balls by hand , cause i dont have especific reball stencil, i dont heat up more than 150 c the audio complier
but after reflow de ic, and try , phone when dialing put in handsfree mode by default and no audio
this happen to me in last 2 phones but this time i have not used preheater on board
Q: do you think that i am need to use preheater to avoid apply to much heat on the board to heat the solder on board and also on ic complier like i used in last 6 ones i was repaired
what is your experience using preheater
thanks for your ponit oif view
Old 06-01-2012, 09:26   #2 (permalink)
Moderator
Wites OM Tesla's Avatar
Member: 1017374
i like too
Hi friend
Sometime if temp is too low there are solder balls that connect to gnd they melt harder possible you need to rise a little the heat or to wait more,but i have other method i give less heat and use solder iron on gnd near this ic so it melt without giving too much heat,this mean that board is heated with solder iron.
Other thing you need protect CPU from too much heat,also some new ic could be defective this why some work but some not work.
Old 06-01-2012, 16:25   #3 (permalink)
Member: 103024
Thanks a lot for answer i will try to use preheater this time and post reaults, also i will try your techinque of using solder iron on gnd ,
In other hand i saw a method posted by you of universal reball technique, i try buy i cannot do pyrimids with good large, which temp u used in iron solder
And which kind of solder are you using
Thanks a lot for info my friend
Old 06-01-2012, 16:35   #4 (permalink)
Moderator
Member: 1017374
I give to solder iron 300C of heat for pyramids make,and use solder wire with flux.
The Following User Says Thank You to Wites OM Tesla For This Useful Post:
Old 06-03-2012, 19:33   #5 (permalink)
Member: 334244
Smile hello..,
hello brother...,
i thing ur problome as same audio ic ,remove and re ball again ,may be dry solder or legs not fixing well...****er meching temp depending models,if u chech any damage board any spare re fixing then change ur mechine temp,then do ur work properly....i thing ur win to ur work..insh*****...
The Following User Says Thank You to yaaz For This Useful Post:
Old 06-04-2012, 06:53   #6 (permalink)
Member: 103024
problem solved by changing the audio compiler and using preheater to put again
seems this component dont tolerate to much hot, or maybe was shorted by the first time
thanks for ideas and your experience
in other hand i have another iphone 4 with audio problems but this is totaly without any sound
handsfree not work
ipod music return to the first menu after try to play
mic not work
also the handsfree its not detected on jack 3.5
i think this time is the audio codec ic, am i right ?
also i think i can use from iphone 3gs its same size , am i correct or its bad idea ?
thanks in advance
Old 06-04-2012, 16:01   #7 (permalink)
Moderator
Member: 1017374
handsfree not work
mic not work
thanks in advance
Yes this U60 problem try reball or replace from 3gs same audio ic.
mr. ice pls save me from disaster pls... marici24 x1x to x45/x50 6 11-30-2001 01:49
TO MR.PRODENT AND ALL!! ABOUT GSM TECHNICAL! andy Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 10-05-1999 11:15
TO MR PRODENT ( REGARDING YOUR INFORMATION ) SP UNLOCKER 2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 10-05-1999 11:04
Nokia 5110 (to Mr.Prodent) Goodfox Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 09-22-1999 07:18
6110 v.5.40 (to Mr.Prodent) alexT Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 09-19-1999 15:59
Page generated in 2.53637 seconds with 11 queries
