04-21-2014, 13:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: dubai
Member: 884639 Status: Offline Sonork: 100.1597105 Thanks Meter: 266 | [NAND] _FindFlashMediaAndKeepout error : iphone 5 i got an iphone 5 with [NAND] _FindFlashMediaAndKeepout error and stuck in recovery mode [NAND ] _FindFlashMediaAndKeepout :601 physical nand block offset 1 [NAND ] start :356 this 0x9f538400 PROVIDER=0x9f6b1f00 flashMedia=0x9f6b1f00 [NAND ] WMR_Start : 149 Apple PPN NAND Driver , Read/Write [NAND ] WMR_Start : 174 FIL_Init [OK] [NAND ] WMR_Open : 371 VFL_Open [OK] [NAND ] s_cxt_boot : 88 sftl : error , unclean shutdown; adopted 11280 spans [NAND ] WMR_Open : 420 FTL_Open [OK] [NAND ] _publishServices : 642 FTL capabilities : 0x00000001 [NAND ] _ppnvflGetStruct : 3469 Checking borrowed blocks - count : 23 max_count : 23 [NAND ] _fetchBorrowedList : 881 number of borrowed blocks 16 *:try to do software restore many times *: replaced battery and tried but same condition any solved solutions thanks & regards |
The Following User Says Thank You to ameerali19 For This Useful Post: |
04-22-2014, 18:46 | #5 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | This cause the promoxity and front camera problem? Fix that or change the lcd the phone is 100% water demage If i helped you press thanks button ↓ |
05-02-2014, 22:36 | #12 (permalink) |
Freak Poster Join Date: Jan 2013 Location: Switzerland Age: 48
Member: 1873863 Status: Offline Thanks Meter: 67 | I had the same problem today, compass ic damaged, removed, and now it work ! Schermata 2014-05-02 alle 23.37.32 copy.png |
