07-21-2014, 20:52 | #21 (permalink) |
Junior Member Join Date: May 2013
Member: 1950628 Status: Offline Thanks Meter: 0 | We are a repair shop as well. Compass IC was the problem here also. Here is the proper way to diagnose this error. When confronted with this error, first, turn on phone without the front camera cable connected at all. If phone boots fine, replace cable. If phone does not boot still, then chances are that compass IC is bad. Our customers upon close inspection has a tiny chip out of the corner. I desoldered it and removed it all together, and it fixed it. That's all we have ran into so far, all problems fixed with this error to date using these solutions. |
08-25-2014, 12:30 | #23 (permalink) | |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Quote:
if phone was booted when you removed the camera flex cable,then you should change that cable or complete lcd it is not so hard to understand Best regards ,, | |
12-17-2014, 08:38 | #26 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | Removing The compass ic Solved my problem . i have been getting error 4013, and error 4005 while restoring...... Phone successfully restored after removing U16 .. BR. |
01-20-2015, 14:27 | #27 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Germany
Member: 1996518 Status: Offline Thanks Meter: 15 | Check resistors. Got the same error with waterdamaged phone. After resoldering the resistors, error is gone. |
The Following User Says Thank You to Exkurs For This Useful Post: |
02-12-2015, 14:20 | #28 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1913935 Status: Offline Thanks Meter: 1 | its camera flex problem , i also had an iphone 5c with nand error , try to put something on the camera flex to isolate it , becouse flex is touching the connector when u put the screen back and gives errors in reading. u can try this to see if it is front camera flex problem before u buy and change with a new one. |
06-22-2015, 20:03 | #30 (permalink) | |
Junior Member Join Date: Mar 2010 Location: The Netherlands
Member: 1261251 Status: Offline Thanks Meter: 4 | Quote:
thanks for sharing guys. | |
