Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-13-2019, 19:14   #1 (permalink)
Member: 2916823
That nand of the ipad supports the naviplus pro 3000s?
Hello, I have a query, how to know that nand supports the naviplus to change the serial and remove icloud? and since some nand does not support them, my question is how to identify the nand that cannot be?
I also have another question, in case of the ipad that are gsm, can these be removed from icloud or not? And if you can, does the sim holder work or not?
regards
Old 11-13-2019, 20:42   #2 (permalink)
Member: 975554
Thanks Meter: 89
ipads that have big nands is not supported for editing serial in navipro 3000s (in my experience)for ipad 2 I always change it and use iPhone 4s nands to edit serial and put in the ipad..
for the other question the answer is NO u cannot use the cellular or simcard again if you bypass the ipad via hardware..the reason is that you will convert it to an ipad that is wifi version only..via server only is the way to remove the icloud that will work if you want to use your ipad cellular as normal..
The Following User Says Thank You to simpleprince49 For This Useful Post:
Old 11-13-2019, 22:13   #3 (permalink)
Member: 2916823
Thanks for the answer, I have a doubt if! Is there no way to identify with any numbering above the nand or something like that to know if it is compatible or not to edit the serial of the nand?
I ask this because I have seen that some ipad 2 nand if they can and some cannot! sorry to ask again, regards
The Following User Says Thank You to Nicaunloc For This Useful Post:
Page generated in 0.19180 seconds with 7 queries
