12-21-2017, 13:30 | #1 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1095293 Status: Offline Thanks Meter: 1 | Need help iphone 6s not charging can any body help me pls......sorry for bad english |
12-21-2017, 13:36 | #2 (permalink) |
Freak Poster Join Date: May 2014 Location: Anywhere
Member: 2182001 Status: Offline Thanks Meter: 52 | Try another Battery full carged and see result, if the problem persist Check the current in the charging mode, if are low then 0.40 Mha change Tristar (shoutdown). |
12-22-2017, 04:18 | #8 (permalink) |
Insane Poster Join Date: Jan 2016
Member: 2518881 Status: Offline Thanks Meter: 4 | First try to see if there is any in system charge port if is there use pin to remove Sent from my iPhone using Tapatalk |
The Following User Says Thank You to frank4i For This Useful Post: |
12-22-2017, 04:19 | #9 (permalink) |
12-25-2017, 07:20 | #11 (permalink) |
Crazy Poster Join Date: May 2017 Location: shenzhen
Member: 2713523 Status: Offline Thanks Meter: 15 | How To Fix An iPhone That Won’t Charge? Hard Reset Your iPhone Check Your Lightning Cable For Damage Try A Different iPhone Charger Brush The Gunk Out Of Your iPhone’s Charging Port Put Your iPhone Into DFU Mode And Restore Repair Your iPhone But if it is a hardware issue, you need to repair, the professional phone repair tools, you can choose Vip Fix Shop Team. |
