05-31-2015, 07:08 | #7 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1668980 Status: Offline Thanks Meter: 35 | Hi Same problem here, iphone 6 itune restore error 40 i will try reheat memory Nand chip, if not work will try reheat PMIC 330C for 2 minutes each I will update my progress history of the phone it was dropped and had a cracked screen so maybe solder balls dislodged under IC' |
05-31-2015, 09:33 | #9 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Gujranwala Age: 33
Member: 1254228 Status: Offline Thanks Meter: 60 | Your device or computer might have a hardware issue that stops the update or restore from completing.
12-28-2016, 00:00 | #10 (permalink) |
Major Poster Join Date: Jun 2016
Member: 2584874 Status: Offline Sonork: 100.1640918 Thanks Meter: 10 | HI, i have 40 pcs nand and i tested with last version iTunes. all same problem (error 40) i think last version iTunes have some problem. |
The Following User Says Thank You to YesFixit For This Useful Post: |
12-28-2016, 05:46 | #11 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1191636 Status: Offline Thanks Meter: 6 | Hi I have iphone 6 Error 40 Replace nand with ip box same error message error 40 Replace ic power it's working now But get error 50 when restore with iTunes |
The Following User Says Thank You to mustafa12 For This Useful Post: |
05-05-2018, 11:51 | #13 (permalink) |
Junior Member Join Date: Jul 2012 Location: philippines
Member: 1782158 Status: Offline Thanks Meter: 5 | iphone 6 plus error 9,40,4013 nand issue, if reheat/reball did not success read out old nand chip info using navi pro,Nand Pro or ipbox then write info to new NAND chip...change NAND chip ...PROBLEM SOLVED |
