Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-23-2014, 14:17   #1 (permalink)
Member: 1983950
Thanks Meter: 8
Exclamation Problem touch screen lock iphone 4s !!
Hi everyone! do you think the lack of the piece that I put in pictures may cause the malfunction of touch!? and hopefully, risaldandolo will solve the problem!?
Thank you all in advance.
http://www.mediafire.com/view/9k4yu0...s/Immagine.png
Old 07-23-2014, 17:17   #2 (permalink)
Member: 1983950
Thanks Meter: 8
Plese help me!! :-(
<img http://www.mediafire.com/view/9k4yu0...s/Immagine.png alt>
Old 07-23-2014, 20:16   #3 (permalink)
Member: 1983950
Thanks Meter: 8
Maybe there are some tracks broken please kindly help me create the right jumpers!!?
Simple File Sharing and Storage.
Old 07-23-2014, 21:19   #4 (permalink)
Member: 1983950
Thanks Meter: 8
I realized that lacks the C341 this may cause malfunction of touch!? can I create jumpers!?
Please help!! :-( :-(
Old 07-24-2014, 07:09   #5 (permalink)
Member: 1983950
Thanks Meter: 8
Excuse me, may I know if I do my subscription to get answers from Wite Ome Tesla!?
Old 07-24-2014, 08:35   #6 (permalink)
Member: 1983950
Thanks Meter: 8
Please jumper for C341 !!
Old 07-24-2014, 13:50   #7 (permalink)
Member: 1983950
Thanks Meter: 8
Nobody can help me? :-(
Old 07-24-2014, 14:06   #8 (permalink)
Member: 1873863
Thanks Meter: 67
No Mastro, NEVER jump capacitors !
Without capacitor, circuit should work anyway.
The Following User Says Thank You to laptopmd For This Useful Post:
Old 07-24-2014, 14:29   #9 (permalink)
Member: 1983950
Thanks Meter: 8
Thanks a lot!! Finally a reply!!! might be a problem with the battery connector!?!? I heard in a post that the battery connector soldered bad might affect ... What do you think!?
Old 07-24-2014, 14:36   #10 (permalink)
Member: 1983950
Thanks Meter: 8
Here are some links to pictures!!
https://forum.gsmhosting.com/vbb/****************************/?kax98zy8p2dysfl
Old 07-24-2014, 15:23   #11 (permalink)
Member: 1873863
Thanks Meter: 67
I will look at the picture at home this afternoon.
What is the main problem of your phone ? Touch not working ?
It was dropped ? Water damaged ?
Does it charge the battery ?
Old 07-24-2014, 15:54   #12 (permalink)
Member: 1983950
Thanks Meter: 8
The touch doesn't work!! no water !! no dropped!! battery charge!! only that during a clumsy attempt to replace the battery, the guy from whom I bought, has damaged the two central tracks of the battery connector, then I've done jumpers between C300 and second pin battery connector and between the third pin C293 battery as specified in the schema of Wites (the battery and charge the iphone work perfectly!!!). The only problem is that in my logic board lacked C293 component and I did the same the jumper even though it lacked the component .... I made a mistake!? This error can jeopardize the smooth operation of touch!? I read on another forum user who had my same problem and solved re-attaching the third pin of the battery was bad soldered!! isn't that maybe it could also be my case!? help me to do some test!?!?
Thanks a lot my friend!!!
look the photos i tink very important!! :-) :-)
Old 07-24-2014, 16:16   #13 (permalink)
Member: 1983950
Thanks Meter: 8
At the link below another photo!
The Following User Says Thank You to mastro7712 For This Useful Post:
Old 07-24-2014, 16:33   #14 (permalink)
Member: 1983950
Thanks Meter: 8
Under other links with photos of the area of the touch!!
https://forum.gsmhosting.com/vbb/****************************/?jj0busbb36o870b
https://forum.gsmhosting.com/vbb/****************************/?rtrp6e19ccm3spc
https://forum.gsmhosting.com/vbb/****************************/?c2iaczsy53dewiy
Old 07-24-2014, 20:25   #15 (permalink)
Member: 1983950
Thanks Meter: 8
No one can give me any other idea!?!?
Page generated in 0.21430 seconds with 8 queries
