08-23-2011, 14:50 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 44
Member: 88333 Status: Offline Thanks Meter: 48 | proximity sensor on iphone 4 for this reason customers complain and i have to replace it several times before having it working please can anybody give me an help thanks a lot in advance |
08-24-2011, 20:18 | #2 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
also check if there is space between 2 sensors , and take a pice of black dak tape and put between them. just compare it to the original and see how it should be , and put black dak tape. if you didnt understand , i will take a pic for you tomorrow what i do | |
09-06-2011, 10:54 | #4 (permalink) |
Junior Member Join Date: Jul 2008
Member: 812714 Status: Offline Thanks Meter: 0 | i had same problem. when back cover is of the phone, proximity works fine, but when put back cover on, it dont work. i put paper between components and cover and it works fine hope it helps, sry about my bad english |
09-21-2011, 19:12 | #7 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1401409 Status: Offline Thanks Meter: 4 | This is a very common problem, I have spent many many hours with proximity sensor faults on many customer's iPhone 4 screen repair jobs. It is almost always caused by parts - either low quality copies, or by mismatched iPhone 4 screens. First thing you need to know is that there are different versions of iPhone 4, and they have are different proximity sensors. The earilest version - IMEI starting with 0124, has a different proximity sensor than iPhones with IMEI starting with 0125. I believe that 0125 to 0127 are all the same. The screens taken from original iPhone 4 are also different between 0124 and 0125. On the 0124 screens the proximity sensor hole on the screen is a large oval shape. On the 0125 onwards screens this proximity sensor hole is divided into two small sections, instead of one large one. If you take a 0124 screen and install it on a 0125 iPhone, the proximity sensor will not work. If you take a 0125 and put it on the 0124, it will work. Many copy screens, and many "original used" ie. refurbished screens, have this 0124 only proximity sensor, and will not work on 0125 iPhones. In addition to this, some copy screens have faulty proximity sensor holes. Summary, it's almost always due to low quality copy parts, faulty parts, or using a 0124 screen (large oval proximity sensor hole) on a 0125 onwards iPhone 4. You can test it yourself, take an iPhone 4 that has a faulty proximity sensor after having had its screen repaired, and reinstall an original screen. Now test it and 90% of the time you'll find that it works fine. Hope that helps. source : My experience conducting iPhone 4 Repairs |
The Following User Says Thank You to iPhoneLove For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
