Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-10-2013, 16:59   #1 (permalink)
Member: 1891566
Reballing Skyworks SKY77541 problem
Today I have an iPhone 4 with "Searching" and "No Service" problem. I bought it cheap. Checked the antenna path all seems to work fine, replace the antenna, clean the metal contacts still no success. I even changed the main board into another housing still no success.
I found the instruction below in this forum. First try, I reheat the two ICs with 285 C, for slightly over one minute each. Success!! but it lasted only like 5 minutes. In this 5 minutes, it found signal, 3G and 2G, can make calls and everything. But then it went back to "Searching" and "No Service"
So, I decided I want to reball the SKY77541. Then I hit this problem.. I was using 180C to preheat, then 300C, airflow setting 4, to unsolder the IC. Probably while I was lifting it, the small capacitors and resistors got pushed away.. I managed to resolder the IC back but now some of the small components are gone: C37_RF, C42_RF, C114_RF, C60_RF, R_35_RF, C63_RF, L9_RF, C165_RF,L5_RF.
My questions:
1. What can I do now? Can I just jump some of the components?
2. Was I using the right temperature and airflow setting? Too much? Too little?
3. How to ensure in the future I don't mess with the components around an IC while unsoldering with hot air gun?
I'm a newbie technician trying to learn. Please give me some pointers.. Thank you..
Old 03-11-2013, 05:41   #2 (permalink)
cal_guy's Avatar
Member: 1430995
Sonork: 100.1613203
Thanks Meter: 305
Is it still turning on????
Important parts you should either replace or jumper them:
R_35_RF, L9_RF
The Following User Says Thank You to cal_guy For This Useful Post:
Old 03-11-2013, 10:16   #3 (permalink)
Member: 1891566
Thanks for the reply. I have not tried to turn it on yet. Will do later and update.
The Following User Says Thank You to wz3k For This Useful Post:
Old 03-12-2013, 00:10   #4 (permalink)
Member: 1716821
Thanks Meter: 4
iff u reballing the SKY77541 dont use more than 240c, u burn insides of ic.
Old 03-12-2013, 05:00   #5 (permalink)
Member: 1891566
thanks. perhaps I have indeed burn the ic inside.. now the iPhone can still be on, but it is stuck at Connect to iTunes logo. Will try to replace it with another IC from another broken motherboard..
what about desoldering temperature? Can 240c desolder the IC from motherboard?
Page generated in 0.21229 seconds with 8 queries
