10-18-2017, 21:47 | #1 (permalink) |
Crazy Poster Join Date: Nov 2015
Member: 2487844 Status: Offline Thanks Meter: 6 | Replace fpc with hot air I have watched videos of those only using hot air to remove connectors quickly and still in one piece. Some doing so with no flux. I have found so far that more heat is better to melt solder before melting the plastic. And that a quick removal is better than spending too much time at it. My concern is overheating the board and any components on other side of pcb. I know that many use low melt solder before hot air as I have in past but sometimes the clearance is so tight it's difficult not to get the solder on other components. Do you use less, more or your usual airflow to remove fpc? Do you use normal nozzle or bigger? (I use 6mm) Are there certain fpc you need to be particularly careful with because of components possibly getting fried on other side? Be so grateful for your thoughts and suggestions. Thanks Chris. |
10-19-2017, 00:02 | #2 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2110834 Status: Offline Thanks Meter: 9 | The fpc connectors on the iPhone 6 and onwards are made of very strong plastic. Usually you can take them off without bur in the plastic. The topic of nozzle size, heat and airflow I think just depends on different tools and personal experience. Just make sure you take all the rubber seal off the components surrounding the connector. When you taking the connector off you don't need flux. Afterwards clean it properly and then put another one on. Sent from my ONEPLUS A3003 using Tapatalk |
The Following User Says Thank You to sunny_lad For This Useful Post: |
