02-09-2011, 10:29 | #16 (permalink) |
Insane Poster Join Date: Aug 2004 Location: United Arab Emirates dubai Age: 42
Member: 77313 Status: Offline Sonork: contact +971529524995 Thanks Meter: 16 | its power supply jumper see it first ur all answer in image |
02-09-2011, 10:43 | #17 (permalink) |
Member: 77313 Status: Offline Sonork: contact +971529524995 Thanks Meter: 16 | remove all component who attach with ground at coil and make a wire direct jump on antenna its simple soultion |
02-09-2011, 12:19 | #19 (permalink) |
Member: 77313 Status: Offline Sonork: contact +971529524995 Thanks Meter: 16 | attach ur phone with ur pc and press power and home booth after that ur set restart now he is in dfu mode leave power button but donut leave home key till end atteach ur phone |
The Following User Says Thank You to sohail_19pk For This Useful Post: |
02-09-2011, 16:57 | #21 (permalink) |
Major Poster Join Date: Aug 2010 Location: Bulgaria Age: 35
Member: 1380602 Status: Offline Thanks Meter: 2 | Hello everyone,and you sohail_19pk...I have i4 4.1 1.59.00 FL at&T,jailbroaken snowbreez,,and I have a problem with it.I drop it and since then i have no carrier signal.Try to restore-doesn't work.install and uninstall ultrasn0w-doesn't work.So i deside it's not software.Then get another i4 and put my motherboard in other.Ithink maybe it's the antena.But again it searscing...searching and says no service.I clean all couplings.So its not the antena,in my opinion.So remains to be samthing on motherboard.Can you give me some solution. |
02-09-2011, 18:15 | #22 (permalink) |
Member: 77313 Status: Offline Sonork: contact +971529524995 Thanks Meter: 16 | your phone will restart when u press home & power key ? if he cant than your home key not work properly |
02-09-2011, 18:20 | #23 (permalink) |
Member: 77313 Status: Offline Sonork: contact +971529524995 Thanks Meter: 16 | when u insert Sim did u get iccid ? if u cant then check your sim points 2ndly re hot your pa and antenna switch or check the point whose came to antenna |
02-09-2011, 18:29 | #24 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: Circuitcorner
Member: 551599 Status: Offline Thanks Meter: 139 | Quote:
http://forum.gsmhosting.com/vbb/f456...olved-1204376/ i solved my problem tnx bro | |
02-10-2011, 17:25 | #27 (permalink) | |
Junior Member Join Date: Feb 2011
Member: 1510912 Status: Offline Thanks Meter: 0 | iphone 3g 8gb Quote:
02-12-2011, 11:50 | #28 (permalink) |
Member: 1380602 Status: Offline Thanks Meter: 2 | sohail_19pk yes i have iccid when insert sim.And one question where is the point whose came to antenna and how to check it? Can you show exactly antenna swicth and the point whose come to antenna..thank in advance.. |
02-12-2011, 15:32 | #29 (permalink) |
Member: 77313 Status: Offline Sonork: contact +971529524995 Thanks Meter: 16 | antenna jumper ImageShack® - Online Photo and Video Hosting |
02-15-2011, 08:46 | #30 (permalink) |
Member: 1380602 Status: Offline Thanks Meter: 2 | IBMOBILES First try to restore from DFU, if doesn't work try to change battery and again restore from DFU or Recovery mode,if not change and power dock...this things worked for me usually |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
