03-27-2014, 13:57 | #1 (permalink) |
Major Poster Join Date: Mar 2014
Member: 2139614 Status: Offline Thanks Meter: 2 | Soldering LCD Connector in iPhone 4S What techniques do you use? soldering with a hot air? do you put the solder on the pads before soldering the port? Thanks for tips Here is a photo below |
03-27-2014, 17:25 | #2 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1952487 Status: Offline Thanks Meter: 43 | this is how i do that: 1. Take solder wick and using a soldering iron wick all the solder you can from the connector pads. 2. put some flux on the connector. 3. using hot air gun, put it on 280c and heat the connector until you see that when you touch it with your tweezers it is moving, than carefully lift it up from the main board. 4. after removed connector, wick again all the solder left. 5. put some solder on your iron, and put some flux on the connector, and put some solder on one pad only. 6. place the new connector and heat that pad that you have put some solder on it until you see that one of the connector legs is holded in place using this pad. 7. than start to solder all left "legs" of the connector. |
The Following 3 Users Say Thank You to arvaser For This Useful Post: |
