Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-21-2014, 17:38   #1 (permalink)
Member: 1996518
Thanks Meter: 15
Smile Soldering U2 back iPhone5
Hi there,
got an iPhone5 which drained Battery very fast.
U2 was heating, so i removed it by putting the solder tip direct onto the chip.
Now i ordered a new U2 chip and want to put it back with hot air.
Anyone can give me an advice which temperature is save to work with?
250°C / low airflow, and hide CPU with small piece of metal cover?
Regards
Old 07-22-2014, 10:48   #2 (permalink)
Member: 1996518
Thanks Meter: 15
I already removed it. Need to solder it back at logic board.
Old 07-22-2014, 11:44   #3 (permalink)
oblio's Avatar
Member: 59869
Thanks Meter: 132
Reball it with leaded solder that will melt at 183 and don't go over 220.
The Following User Says Thank You to oblio For This Useful Post:
Old 07-23-2014, 07:03   #4 (permalink)
Member: 1873863
Thanks Meter: 67
Exkurs cover the cpu with a coin, like a 2 Euro's coin, it's good to shield the cpu from heat.
The Following User Says Thank You to laptopmd For This Useful Post:
Old 07-23-2014, 10:44   #5 (permalink)
Member: 1996518
Thanks Meter: 15
Hey,
Thanks laptopmd, will keep that in mind.
Around 210•c outlet is safe? Which nozzle diameter? 10mm?
Old 07-24-2014, 22:00   #6 (permalink)
Member: 1873863
Thanks Meter: 67
6mm if you have, otherwise 10mm :-)
Old 07-24-2014, 22:07   #7 (permalink)
Member: 1996518
Thanks Meter: 15
I have both of them, so I will use the 6mm nozzle
Old 07-24-2014, 22:17   #8 (permalink)
Cheater -Don't Deal with him-
Member: 2089356
Sonork: Threema: 3N5W6VV9
Thanks Meter: 520
yea i have those problem i had problem re-placing this , thnx all for infos, mine after remove the ic and placed again phone was dead,,, please post again if phone is succsesfuly repaired i wanna know
Old 07-24-2014, 22:25   #9 (permalink)
Member: 1996518
Thanks Meter: 15
Never did this repair before, so the risk to damage the device is high I think.
I will try,since I can't use it with damaged U2 I have nothing to lose..
When you have placed it back, aligned it properly and use little of airflow it should work
Old 07-24-2014, 22:55   #10 (permalink)
Member: 2089356
Thanks Meter: 520
maybe i did the aligned wrong, but i should study practice more on ic replacing, when you decide to replace and post result please Bite,
Old 08-11-2014, 11:14   #11 (permalink)
Member: 1996518
Thanks Meter: 15
I replaced the chip yesterday.
Reballed it with leaded solder, covered the CPU with two euros.
I used 290c (display value) with 6mm nozzle, 3.0 airflow.
Took some time to get to the desired temperature.
I permanently watched through my microscope until solder melted.
Phone works like designed now.
The hardest part was reballing the chip without additional tools, but with 0.1mm tip.
Old 08-11-2014, 11:51   #12 (permalink)
Member: 530705
Sonork: 1616834
Thanks Meter: 833
How to remove ic with soldering iron.. pls describe bro i am new..
Old 08-11-2014, 12:09   #13 (permalink)
Member: 1873863
Thanks Meter: 67
Great job Exkurs !!!
this weekend i had to do this too, but i have removed the chip with the iron, and reballed by placing balls by hand (kostelektronik style).
Old 08-11-2014, 13:13   #14 (permalink)
Member: 2205919
Thanks Meter: 33
I use 380degree and always work! It's take about 1 minute to soldier but i replace a lot of U2 chips and always success
Old 08-11-2014, 13:16   #15 (permalink)
Member: 2205919
Thanks Meter: 33
to remove U2 i use 180degree, and slowly remove glue from U2 chip and around it... then i heat it with 380degree, remove, then 180degree remove rest of the glue under it and that's it
Page generated in 0.26237 seconds with 8 queries
