05-30-2015, 22:13 | #1 (permalink) |
Junior Member Join Date: May 2015
Member: 2399894 Status: Offline Thanks Meter: 3 | Soldering U2 chip (what tools needed) I would like to start micro soldering, i have phone compagny but sometime we broke some chip during repair. What is all tool needed for remove U2 chip and replace with new one ( i already have the new U2) Can someone explain me how to desoldering and how to soldering back, which method is the best ? Thanks |
05-30-2015, 22:33 | #2 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Micro electronics works need looooots of experience. I suggest you to take some old pub and do many trials to find goodcways. Anyway, you will work on bga so need to use either hot air or infrared technology. Last edited by excessive; 05-30-2015 at 23:01. |
05-31-2015, 10:55 | #3 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2157594 Status: Offline Thanks Meter: 1 | Hello.. First of all you will need a Microscope. Second, a hot air station. Third a good pair of anti magnetic tweezers, flux and a loooooooooooot of patiance. As excessive said i would recommend to start with an old pcb which you can throw into trash if your experiments fails. This Kind of soldering keeps a lot of surprises for you. Start with the smallest IC and then try bigger ones. You have to care a lot of for temperature, and air flow. If there is black resin around the chip, remove that first. Then try with at least 250-350 C to remove the chip. Be aware of the black resin! Its most of the time underfilled with the IC. If you pull too early your board is damaged because of ripping of the little pads on the board. Maybe i will post some pics of successful removing... |
06-01-2015, 16:22 | #5 (permalink) |
No Life Poster Join Date: Oct 2005
Member: 194907 Status: Offline Thanks Meter: 114 | Here is the u2 ıc removal profesional tool https://www.youtube.com/watch?v=oODpj71kxjA |
