05-19-2017, 18:06 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: nigeria .benin
Member: 2495283 Status: Offline Sonork: gsmvilla.com Thanks Meter: 12 | Check voltage I don't thinks it 6.3 in the pic ...each time I measure even with a new phone I don't get the 6.3 Sent from my iPhone using Tapatalk Pro |
05-19-2017, 18:40 | #2 (permalink) |
Junior Member Join Date: Mar 2017 Location: Slovenia
Member: 2697148 Status: Offline Thanks Meter: 23 | On the picture is nominal voltage for the cap. The cap is made for 6.3V if you put over 6.3v to the cap can be destroyed.. C1640 is the number capacitor on the board or schematic 4.7uF 20% 6.3V is the manufacture data. C1640 is for the PP_SPKAMP_FILT line probably filter. |
The Following User Says Thank You to blckshep For This Useful Post: |
05-19-2017, 21:40 | #8 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2106911 Status: Offline Thanks Meter: 67 | look on schematic for PP_SPKAMP_FILT so you get page 26 =======> 1.8 VOLT and page 16 you get V=1.0 so you can have 1.0 -1.8 ( not sure i do this only as hobby) |
The Following User Says Thank You to vinse For This Useful Post: |
05-20-2017, 05:39 | #12 (permalink) |
Member: 2495283 Status: Offline Sonork: gsmvilla.com Thanks Meter: 12 | Check voltage To know the voltage of a cap ..I need to know the ic line the cap is connected to and use the name to check volts in voltage properties?? Sent from my iPhone using Tapatalk Pro |
