02-07-2017, 17:32 | #1 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2682123 Status: Offline Thanks Meter: 0 | Stumped By iPhone 6 Reboot Loop Phone Information
Problem Symptoms
Problem Origin
Troubleshooting
I am completely out of ideas. If you have any suggestions that may save my phone I would love to hear them; will ship beer for an idea that works! |
02-07-2017, 18:40 | #2 (permalink) |
Freak Poster Join Date: Jan 2015
Member: 2332350 Status: Offline Thanks Meter: 15 | You need to check if you didnt damage the pcb while changing the lcd. Also you will have to check screw holes with microscope to see if you didnt make any screw damage to board layers. |
02-08-2017, 14:32 | #3 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | hi you problem seems to be charging ic alias U2 ( for IPH.6 <U1700>) and / or Q1701 ..replace U1700 and test starting with battery to zero charge. |
02-15-2017, 19:15 | #4 (permalink) |
Member: 2682123 Status: Offline Thanks Meter: 0 | Thanks, Orx. I've been doing some reading to make sure I understand what you're saying. Can the Charging IC be the cause even through the battery seems to discharge and charge normally? I can leave the phone stuck in restart loop until the battery dies and phone indicates that I need to plug in. If I plug in for 10-15 minutes the phone will restart. |
02-15-2017, 22:19 | #5 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | hi usb / charging IC , in your case after replace dock and battery is the successive step . Battery with quick discharge e request of to connect power charge can to be the symptom. |
09-08-2017, 07:54 | #7 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2755514 Status: Offline Thanks Meter: 0 | Here are 3 options to fix iPhone Stuck in Boot Loop: 1. Checking the battery connector 2. Putting your iPhone into Recovery Mode 3. Upgrade and restore your iPhone with iTunes. 4. Using iMyFone iOS System Recovery. |
09-12-2017, 10:53 | #9 (permalink) | |
Member: 2755514 Status: Offline Thanks Meter: 0 | iPhone Stuck in Boot Loop Quote:
03-03-2018, 21:07 | #12 (permalink) |
Junior Member Join Date: May 2017
Member: 2716819 Status: Offline Thanks Meter: 0 | you should try the logic board in known good housing with known good battery etc , if problem persists then you have a logic board problem , check the board for visible damage under microscope , the phone is boot looping so is not getting the message to turn on tristar is the usual culprit but can be anything on that line , so change tristar which is quite a simple process then take it from there good luck |
07-25-2019, 07:23 | #14 (permalink) |
Insane Poster Join Date: Jan 2018
Member: 2797527 Status: Offline Thanks Meter: 4 | The reasons, like wrong update, device jailbreak and battery problem, can cause this iOS issue. If you want to fix iPhone stuck in boot loop, you might as well simply force restart, use iTunes, or repair with iOS system recovery or something else, like Volumn Up trick, etc. Hope you can get out of this trouble soon. |
08-14-2019, 04:05 | #15 (permalink) |
Member: 2755514 Status: Offline Thanks Meter: 0 | Here are different solutions to fix iPhone stuck in boot loop issue. If these solutions are not workable for you, try iOS System Recovery program. |
