Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-16-2012, 14:24   #1 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
temperature iphone needs to cool down before you can use it 100% slove by gopalhot
this iphone use 5 mt and show this warning and back side very hot
i am slove this problem today. its very hard operation
remove this
broabcom BCN4329FKUBG 11N with Bluetooth 2.1 + EDR and FM receiver
dont use hot air gun
look this photo in zoom
remove all parts in red mark
not say thanks use thanks button
if any problem
[email protected]
Gopal Karmakar | Facebook
The Following 10 Users Say Thank You to gopalhot For This Useful Post:
Old 08-16-2012, 14:43   #2 (permalink)
sharif_tell's Avatar
Member: 789364
Sonork: 100.1585484
Thanks Meter: 191
any other effect after remove all ic from that section?
Old 08-16-2012, 14:45   #3 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
YES NOT WORKING WIFI
The Following User Says Thank You to gopalhot For This Useful Post:
Old 08-18-2012, 12:57   #4 (permalink)
Member: 1477098
Thanks Meter: 16
That's it?! Then you call the problem solved?
Old 08-18-2012, 13:47   #5 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
you removed BLUETOOTH /FM RECEIVER, AND GPS RECEIVER.
SO THE PROBLEM BEGINS FROM HERE...............
Old 10-28-2012, 21:49   #6 (permalink)
Member: 1831810
Thanks Meter: 2
it's wrong solution i try to remove WIFI ic and blutooth but it's still show Iphone needs to cool down before you can use it , so now i have 2 problem temperature and WIFI oh why you share wronge solution ?????????
The Following User Says Thank You to E_MAX For This Useful Post:
Old 10-28-2012, 21:49   #7 (permalink)
Member: 1831810
Thanks Meter: 2
Old 10-28-2012, 22:52   #8 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,594
Yes you are right this is bad solution i will delete from the sticky thread.
The Following 3 Users Say Thank You to Wites OM Tesla For This Useful Post:
Old 10-29-2012, 02:19   #9 (permalink)
Member: 1679608
Thanks Meter: 190
yes it's right maybe the problem in another port like PMIC if the PMIC gets hot the iphone show this msg
when you see this msg its mean some port in the iphone shorted
The Following 2 Users Say Thank You to air_chair256 For This Useful Post:
Old 10-29-2012, 04:54   #10 (permalink)
alayne's Avatar
Member: 162029
Thanks Meter: 202
I encountered this problem already and I just replaced battery and all is well maybe different cases causes this temp problem
The Following User Says Thank You to alayne For This Useful Post:
Old 10-29-2012, 05:06   #11 (permalink)
miguel_john1975's Avatar
Member: 586346
Thanks Meter: 113
its a case to case basis..when that part is on heat then thats the part you need to remove but if not heating then dont do it..
done 1 before upon inspection found out that the board is shorted with water,, in some connector so clean... assemble... done..
EXAMINE BEFORE YOU DO IT
The Following User Says Thank You to miguel_john1975 For This Useful Post:
Old 11-07-2012, 16:43   #12 (permalink)
Member: 1759291
Sonork: shajahankt
Thanks Meter: 4
be cool guys... might be one issue have possible different cause and solution.....
Old 11-07-2012, 23:53   #13 (permalink)
Member: 302596
Thanks Meter: 784
you need to trouble shoot,, if you have digital volt tester or signal frequency meter you can trace this problem, just check the proper voltage flow to the charging ways may be the problem is in there
Old 11-07-2012, 23:55   #14 (permalink)
Member: 302596
Thanks Meter: 784
he show only the solution but he didnot show the phone if fully working or not, so may be this solution is not officially working as other said
Old 03-13-2014, 18:40   #15 (permalink)
Member: 1638193
Thanks Meter: 8
i solve also this problem by changing battery
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.25796 seconds with 10 queries
