03-05-2017, 18:53 | #1 (permalink) |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | Touch ID not working iPhone 6 Cleaned corrosion, resoldered some corroded pins and now phone boots and home button works but Touch ID fails and can't be set up. Is there a schematic for the home button itself? |
03-05-2017, 19:13 | #2 (permalink) | |
Moderator Join Date: Feb 2006 Location: Bangladesh & Bahrain
Member: 233205 Status: Offline Thanks Meter: 5,014 | Quote:
no schematic for home button. check under microscope you will found some corroded pin under home button connector re-solder them carefully + change long flex cable which ic connected between button and pcb. | |
The Following User Says Thank You to tkowsar For This Useful Post: |
03-05-2017, 19:14 | #3 (permalink) | |
Member: 2598526 Status: Offline Thanks Meter: 52 | Quote:
I've done that. Still same issue. Any component on the home button that would cause id not to work? No corrosion on logic board side | |
04-02-2017, 02:13 | #4 (permalink) |
Member: 2598526 Status: Offline Thanks Meter: 52 | Anyone experience this or know which components on home button itself is responsible for fingerprint? |
The Following User Says Thank You to short_toground For This Useful Post: |
04-02-2017, 13:50 | #7 (permalink) | |
Crazy Poster Join Date: Apr 2012
Member: 1750776 Status: Offline Thanks Meter: 26 | Quote:
http://jam-gsm.com/soft/wp-content/u...ys-291x300.jpg use g translate: iPhone6·µ»Ø(home¼ü)°´¼üʧÁé¡¢Ö¸ÎÆʶ±ð¹ÊÕϵĹؼü²âÁ ¿µã¼°Î¬ÐÞ·½·¨ - | |
The Following User Says Thank You to xcell21 For This Useful Post: |
