02-14-2016, 18:19 | #1 (permalink) |
Major Poster Join Date: Jan 2016
Member: 2517535 Status: Offline Thanks Meter: 1 | Ultrasonic Cleaning, How Long to Do It? |
02-14-2016, 20:57 | #2 (permalink) |
No Life Poster Join Date: Mar 2012 Location: cambridgeshire, England Age: 55
Member: 1728699 Status: Offline Thanks Meter: 212 | No success ? you mean it didn't clean the boards? just experiment with the tempreture, and timing, Most i put them in for is 12 mins. |
The Following User Says Thank You to dog68 For This Useful Post: |
02-14-2016, 23:34 | #4 (permalink) |
Member: 1728699 Status: Offline Thanks Meter: 212 | I use both, and often mix both with a spot of detergent. I take it the boards you have are water damaged? I have a 100% success rate, as i only expect my machine to clean them, lol. water damaged phones, need re-soldering, in my opinion |
02-14-2016, 23:40 | #5 (permalink) |
Freak Poster Join Date: May 2008
Member: 777576 Status: Offline Thanks Meter: 32 | you want to use water, to clean the board from water?!?!? you wanted to say something different, i hope... about 10-15 minutes should be more then enought, meanwhile you also can take the board out and clean it with tooth brush or something similar, then put it back again. this cleaning can help you to get rid of some dirt, left from water, but you can not make the board "new" with it, especially if the board haven't been cleaned up right after it got contact with fluids. as much sooner you clean the board, that much bigger is the chance that the alcohol (or similar) cleaning will help you to rescue the board, BEFORE the water (or whatever) made the damage to the board, which you can not repair later... |
The Following User Says Thank You to moding For This Useful Post: |
02-15-2016, 00:05 | #6 (permalink) | |
Member: 2517535 Status: Offline Thanks Meter: 1 | Quote:
02-15-2016, 00:05 | #7 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | Agree with dog68. Mix of deminalised water some alcohol and anti cal to clean to metal of a shower head works great. Makes your connectors shine. Only alcohol will not work when you have soft drink damage or other sugar stuff on the board. Use compressed air to clean board or use your hot air gun on low temperture and high air flow to clean the water away under ic's Just turn the ultra sonic bath on for a few runs of 3min is enough. After the bath, you should check for bad connections and shorted caps. |
The Following User Says Thank You to HDccam For This Useful Post: |
02-15-2016, 11:48 | #9 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2531997 Status: Offline Thanks Meter: 4 | We would use a detergent called Galvex 17;13 for cleaning PCB’s. You can dip them in alcohol after cleaning to dry them. Be careful with alcohol in a heated ultrasonic tank as the flashpoint is very low and could cause an explosion of fumes. |
The Following User Says Thank You to jlanders For This Useful Post: |
