Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-29-2013, 18:46   #31 (permalink)
Member: 2055674
i had a iphone 5 with broken Compass IC Broken.
it cannot activate before when i make a reset all content and setting then
I restored it to itunes, now the problem is giving me error 1669
i tried diff original cable as well as different computer, Mac and Windows but still giving me error.
Old 11-15-2013, 15:00   #32 (permalink)
Member: 117190
same problem with me! any luck? :/
Old 11-16-2013, 10:20   #33 (permalink)
memas_trading's Avatar
Member: 1797460
Sonork: 100.1622335
Thanks Meter: 24
bro try to restore network setting
Old 11-18-2013, 01:53   #34 (permalink)
Member: 117190
I already tried to restore network setting but no luck :/
Old 01-30-2014, 22:42   #35 (permalink)
Member: 2117971
same issue
i have the same issue when i replaced power / volume control flex,
my iphone is a verizone version and i am stuck with it, it can not see any other network as well,
please help
Old 04-01-2014, 17:38   #36 (permalink)
Member: 1418896
Sonork: mjd_76_09
Thanks Meter: 3
what the f***k is this problem. i replace the power cable then no service. i check all the board nothing damage all look perfect. any solution please. stupid device G O D bless nokia and microsoft.
Old 04-02-2014, 16:05   #37 (permalink)
Member: 2136675
Hi for all guys,
I have replaced my back camera on iphone 5 and after reasembling the phone i have got NO SERVICE , the phone was factory unlocked. I have tried many restarts, reset of network settings and hard reset ( power button + home button in the same time pressed) then he got service again , try all these and problem will be resolved.
Also i have opened the phone again to check other screen and also after this got NO SERVICE, problem was resolve like first time, hard reset, reset network settings and a few restarts.One of them have worked..
try all this..maybe it will resolve the problem.
Old 04-03-2014, 15:25   #38 (permalink)
Member: 1081268
Thanks Meter: 73
go to general>date&time>turn on set automatically
then connect ur wifi restart ur phone
put ur sim show no service then remove sim
and put again.....
Old 04-06-2014, 04:45   #39 (permalink)
Member: 374177
Thanks Meter: 22
try my friend to remove the power cable and check if the signal is back. power cable can cause that problem.
Old 07-29-2014, 23:56   #40 (permalink)
Member: 226788
Thanks Meter: 3
Hello
I have the same problem after change rear camera i got no signal. I would like to try your solution but please can you tell me what is the powe cable? Sorry for this stupid question
Old 09-05-2014, 17:35   #41 (permalink)
Member: 2130351
Originally Posted by sandy2626 View Post
Hello
did u got any solution for this.??? same prob with iphone 5 no signal after replacing rear camera
Old 09-22-2014, 21:06   #42 (permalink)
Member: 2012593
Thanks Meter: 4
I have seen searching no service many times in iPhone 5. Check very carefully for *any* damage to U601_RF. This is the glass ic that lies under the interconnect cables near the dock connector. The slightest damage to this ic will cause the phone not to find service. If you see this damage, check under settings to see if your phone is producing an IMEI or if it has a number next to modem firmware. If not, U601_RF is your problem.
Old 09-22-2014, 21:29   #43 (permalink)
Member: 226788
Thanks Meter: 3
Hi
In my case i have IMEI number and modem firmware. And the operateur appears. What do you think about that?
Thanks for your help.
Old 09-22-2014, 21:36   #44 (permalink)
Member: 226788
Thanks Meter: 3
I am searching a solution for this problem but nothing, no network on my iphone 5 after rear camera replace.
Old 12-15-2014, 12:54   #45 (permalink)
Member: 687854
Exclamation iPhone5 no service after disassemble
I got same pblm after change the pwr strip. Just connect iTunes with original cable with working SIM, after successful connection just go to >Settings & activate Airplane mode & deactivate after few seconds of searching it'll Done
Page generated in 0.20513 seconds with 9 queries
