Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-28-2012, 09:04   #1 (permalink)
Member: 1764726
Water damaged i4 not charging (new battery and dock)
Everything seems to work but no charge, can someone kindly point me in the right direction to make a jumper or the part that needs replacing (its not the dock or battery before anyone says)
Old 07-28-2012, 16:18   #2 (permalink)
Member: 1790515
did water come to the board ?
Old 07-30-2012, 19:55   #3 (permalink)
Member: 1764726
yes i assume so, water stickers are pink but cannot see any signs of water damage on any of the connectors
Old 07-30-2012, 19:58   #4 (permalink)
DomnulV's Avatar
Member: 1447
replace battery..100% controler in battery is affected by wather..tested on two phone
look at battery controller ..replace battery sticker
Cris
The Following User Says Thank You to DomnulV For This Useful Post:
Old 07-30-2012, 20:06   #5 (permalink)
Member: 1790515
yes...try to replace battery first...but you have to let the iphone dry for a couple day or use the heat gun
Old 07-30-2012, 20:26   #6 (permalink)
DomnulV's Avatar
Member: 1447
It is very dangerous to use hot air on iphone....Was two point of wather (on display connector and in battery)..with iron and alchool you can clean and resold all affected component.
And replace battery.....the phone show charging but dont charge..
good luck
Old 07-30-2012, 20:29   #7 (permalink)
Member: 1747011
Hello Guys, I post in this topic because I have almost the same problem, I have an iphone 4 which is the first in tea and then fell into the water, I wiped perfectly clean and everything seems to work, the battery is good the changed, the iphone works fine, but when you get to 0 will not charge the battery ... I have to insert it into another iphone and then charge it again, as if the phone discharge the battery even when turned off ... help me I do not know what else to do .. SORRY MY ENGLISH .. have an Italian engineer
Old 09-19-2012, 23:02   #8 (permalink)
Member: 1803358
i have the same problem!
the battery just runs dry very fast. i replaced the battery connector because it was broken off.. i resoldered all of the battery connector points but no charging..
it says it's charging but it is fake, is there a solution to this problem?
Old 09-20-2012, 02:56   #9 (permalink)
Member: 1679608
check the battery connector how many volt it have on + it's must be 1.5 v and check FL7_RF and FL5_RF if not good replace them . also check R81 when the phone on charge its must have 4.2 or 5v
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
Page generated in 0.49386 seconds with 12 queries
