Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-13-2020, 21:36   #1 (permalink)
Member: 1212133
Thanks Meter: 46
What equipment to use?
Hi
what kind of glue removing tool do you use ?
I did not find any glue removing tool that would be strong enough ( not being bent), yet thin enough? An example removing glue around of power IC on Iphone 7
Can you post your tips?
Thanks
Old 02-14-2020, 01:40   #2 (permalink)
Member: 2500623
Originally Posted by Jane1 View Post
Hi
Thanks
Hi,
Qianli ToolPlus 007 and 008 plus low temp hot air just to soften the glue and youíll be just fine.
Sent from my iPhone using Tapatalk
The Following User Says Thank You to VisionSoul For This Useful Post:
Old 02-14-2020, 11:47   #3 (permalink)
Member: 1212133
Thanks Meter: 46
I use more or less the same tool like Qianli ToolPlus 007 but it is not thin enough so that I can remove properly glue around power IC in Iphone 7 model.
Are you sure that Qianli ToolPlus 007 is thin enough ?Thanks
Old 02-14-2020, 11:51   #4 (permalink)
Member: 2500623
I think so. Check their products at unionrepair, and youtube to see tools working.
Best regards
Old 02-14-2020, 15:31   #5 (permalink)
Member: 1212133
Thanks Meter: 46
Do you THINK SO or do you HAVE experience ?
Old 02-14-2020, 15:36   #6 (permalink)
Member: 2500623
I did not remove any ic with it yet, since i got it.
Old 02-14-2020, 15:40   #7 (permalink)
Member: 2500623
But tool is not that so expensive that you canít buy it for testing and see if it fits your needs. Around 10$ for each set.
Old 02-14-2020, 19:31   #8 (permalink)
Member: 975554
Thanks Meter: 89
any tools can do s long as your an experienced tech..even the cheapest pry tool does the job..just need to be careful in any job that you do..combination of hotairs air and heat level also is needed for this to work
Old 02-15-2020, 04:09   #9 (permalink)
Member: 2730637
Thanks Meter: 15
Can't agree more. I have been a fan of REWA Youtube Channel and I can always watch their masters using the easiest tool to complete the hardest repair work in their video.
Old 02-15-2020, 09:20   #10 (permalink)
Member: 1212133
Thanks Meter: 46
Agreed. If the tool is not thin enough you can remove glue( also called black underfill) between IC and other parts. I used the tool like Qianli ToolPlus 007 . It worked well until I came accross Iphone 7 where I needed to desolder power IC (U1801). The gap between IC and other parts( on one side) was very thin for the tool I used.
Old Yesterday, 09:26   #11 (permalink)
Member: 767178
You show no equipments or Tools !
Page generated in 0.14630 seconds with 7 queries
