06-22-2016, 16:15 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: spain Age: 35
Member: 65061 Status: Offline Thanks Meter: 30 | What temperature is propely for NAND replace on apple devices? |
06-22-2016, 16:28 | #2 (permalink) |
Insane Poster Join Date: Jan 2015
Member: 2334955 Status: Offline Thanks Meter: 20 | 380c to 420 airflow 4 to 6 i dont tend to use seconds as a guide i use an exacto knife when it slides under gentle upwards pressure to flick off the nand. |
The Following User Says Thank You to modityx For This Useful Post: |
06-23-2016, 09:37 | #3 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | to consider also the problem of cooling the opposite side of the board ..es iphone 5 / 5s for overheating CPU. so before removing the nand place the board on a metal part to dissipate heat, invent something. Last edited by orx; 06-23-2016 at 09:44. |
06-24-2016, 00:18 | #5 (permalink) |
Member: 2334955 Status: Offline Thanks Meter: 20 | iPad 2 iPhone 4 revision with small NAND chip iPad 3 (if 2 NAND flash chips than SN in U1400 chip?) iPhone 4s, iPhone 4 (?) iPad 4 iPhone 5 iPad mini 1 gen iPhone5, iPhone 4? (revision with small NAND chip?) iPad Air 1 gen iPhone 5s or iPhone 6 iPad mini 2 gen iPhone 5s iPad Air 2 gen iPhone 6 iPad mini 3 gen iPad Pro 1 gen iPhone 6s iPad mini 4 gen iPad Pro 8.9″ (Air 3) iPhone 6 or iPhone 6s |
07-01-2016, 20:15 | #11 (permalink) |
Insane Poster Join Date: Jun 2016
Member: 2582013 Status: Offline Thanks Meter: 2 | hello guy today i tried to remove the nand of ipad 4 but i couldnt i lift some pads from the nand socket so i ****ed up the logic board ... i am using hakko 802 hot air station and with big nozzle about 1 minute at 380C it couldnt remove nice and clean.. before start removing the nand i remove the glue , preheat about 1 minute the board and after that i start ... now i have ordered another board and will try again , but before that will practice on another boards and will wait for some advice .. i have a plan now , will start from the CPU direction , by removing this metal frames and from there will be more more easy i think , because today i tried from corners and i couldnt |
The Following User Says Thank You to pApit0o0o0 For This Useful Post: |
07-03-2016, 16:42 | #13 (permalink) | |
Freak Poster Join Date: Oct 2011
Member: 1675922 Status: Offline Thanks Meter: 61 | Quote:
Sent from my HUAWEI Y550-L01 using Tapatalk | |
09-30-2016, 20:36 | #15 (permalink) |
Insane Poster Join Date: Oct 2003 Age: 38
Member: 41057 Status: Offline Thanks Meter: 5 | today changed two nand on ipads mini3. old nand desoldered with 300c, balls added to new nand with 240c on preheather and then soldered nand to mainboard with hotair on 270c. Both ipads works fine |
