08-24-2016, 22:25 | #19 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | for reballing depend where you reball ..example , U2 5s (no danger zone ) i use 345 air to level 4..anyway is important which rework station you have . Flux is very important for all work process ..quality flux and quality tin solder paste help you. |
08-25-2016, 20:24 | #23 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2453408 Status: Offline Thanks Meter: 63 | You are trying to heat IC with uderfill, balls will always squeeze out from uderfill when expanding under high temp. Just lift it with sharp, very thin tool and clear glue, don't bother about balls running all around the board. |
08-25-2016, 21:22 | #24 (permalink) | |
No Life Poster Join Date: Jul 2016
Member: 2598526 Status: Offline Thanks Meter: 52 | Quote:
So you can't simply "reflow" a chip that has underfill? It needs to be removed because solder balls always squeeze out? | |
08-25-2016, 21:43 | #25 (permalink) | |
Member: 2453408 Status: Offline Thanks Meter: 63 | Quote:
Its possible to heat it up a little to only melt surfaces of solder balls but what temperature and how long exactly there is not straight answer, boundary between overheating and proper reheating is very thin, in practice I never had long standing success with such method. | |
08-25-2016, 22:20 | #27 (permalink) | |
With high airflow you can see when solder balls melted so you have better control over whole process. | |
