05-10-2015, 08:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | ::..<<<<World 1st Privacy Lock reset Done Without Data Lost>>>>.:: Read Info Code: Chinese Miracle II [MTK module] v 1.20 Operation : Check / Read Info [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001A060D1FFC197 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 0EG40 [eMMC] : FLASH_CID : 11010030303447453001A060D1FFC197 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Intex ProdName : Y2_Pro ProdModel : Aqua Y2 Pro Device : Aqua_Y2_Pro AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : Intex_Aqua_Y2_Pro_V11_Indian Done! Elapsed: 00:00:15 Reconnect Power/Cable! Privacy Lock reset Ok! Code: Operation : Reset Privacy Lock [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 11010030303447453001A060D1FFC197 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0011 , OEM : 0100 [eMMC] : FLASH_INF : 0EG40 [eMMC] : FLASH_CID : 11010030303447453001A060D1FFC197 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Processing with "Safe UserData" mode SafeDetect : Done! Will reset now! Privacy Lock reset Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! Infinity@Cm2 Rocked, Other Shocked What Is Next? |
The Following 9 Users Say Thank You to pradeep_kus For This Useful Post: |
05-10-2015, 12:37 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Testing will be 1 more day. If someone have PL locked eMMC phone ( NAND will be in next, if find sample ) - PM for obtain beta. More fun will follow |
05-10-2015, 14:54 | #7 (permalink) |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Hello This Is Already Supported , Always Checked In News Section http://forum.gsmhosting.com/vbb/10984018-post1037.html |
05-10-2015, 18:13 | #8 (permalink) | |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Quote:
Code: Analysis of USB port,Please insert phone USB cable. Connecting... Hardware version:CB00 Software version:0000 CPU TYPE:6260 Internal version:8000 Boot downloading complete! Flash ID: 00EF004000160000 Flash Type: SF_W25Q32BV Chip Capacity: 0x300000(3MB) Baud adjust...complete. Flash reading complete! privacy:2644 privacy:0000 >>The data has been saved in C:\Documents and Settings\MUHAMMAD FARHAN\My Documents\m400.bin, size: 3 M. Code: Wait for phone... Phone found! [ 253 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 6DF7EE49EB8D1B11C22AC85BCDC736BC BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Read ExtData Sorting ExtData Reading UserCode Active : No , Code : 0000 PLock|MobTrack : Not active Done! Elapsed: 00:00:07 Reconnect Power/Cable! | |
05-11-2015, 01:31 | #9 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
05-12-2015, 10:25 | #10 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | hi JayDi tanha is right cm2 read just user code not read privacy code and no success post about privacy code of mtk 625A 6260 6261 |
