10-14-2013, 12:51 | #1 (permalink) |
Insane Poster Join Date: Jul 2013 Location: Delhi, india
Member: 1979321 Status: Offline Sonork: 100.1647636 Thanks Meter: 10 | infinty is not working not connecting any b series samsung phone by rj45 cable, always showing this error COM1 [Serial0] selected module v1.94 Device: Samsung-SCH-B209, B229, B309, B319, B619, B339FM operation: Rebuild EFS/NV Phone should be Switched ON ! connecting... Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" error: operation failed Finished, time used: 22 sec i have treid with this code also 47*869#123580 tried in 5, 6 sets... not a single set is connecting i have also changed 2 e210 cables infinity help me plzzzzzzzzzz its urgent |
10-14-2013, 13:42 | #2 (permalink) | |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | Quote:
Dear meghalaya, Kindly follow the step as given below . 1)Use-RJ-45 cabel samsung E-210 . 2)Press in phone 47*869#123580 3)Goto HFK mode Select UART-2 4)Select model from list Device: Samsung-SCH-B209, B309, B319, B619, B339FM 5)Go to Service Tab click SP-UNLOCK 6)Wait till operation done . 7)After operation done check with other Ruim card and don't forgot to post logs. | |
The Following User Says Thank You to .::TEJARAM::. For This Useful Post: |
10-14-2013, 17:29 | #3 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Haider Pur (DELHI)
Member: 1777416 Status: Offline Sonork: 100.1647840 Thanks Meter: 129 | Dear meghalaya, Kindly follow the step as given below . 1)Use-RJ-45 cabel samsung E-210 . 2)Press in phone 47*869#123580 3)Goto HFK mode Select UART-2 4)Select model from list Device: Samsung-SCH-B209, B309, B319, B619, B339FM 5)Go to Service Tab click SP-UNLOCK 6)Wait till operation done . 7)After operation done check with other Ruim card and don't forgot to post logs. brother this write solution ...100% done am tasted near about 10,000 handset. |
10-15-2013, 05:01 | #4 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
Also Check Cable And Follow All Steps Wbr <<<Megatron>>> | |
