07-18-2010, 05:41 | #5 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i also get this range check error when i find the pinout of a cdma handset using the infinity pinfinder , so i stop using pinfinder for cdma handsets ... this means range check error comes when there is fault in the cable or pinout .... |
07-19-2010, 14:54 | #6 (permalink) |
Freak Poster Join Date: May 2009 Location: Hazaribag Age: 35
Member: 1040838 Status: Offline Sonork: 123 Thanks Meter: 29 | dongal can't be found card with specied AID is not found smart card API error #00000000 The opration completed successfully. plese help........... |
The Following User Says Thank You to deepak592 For This Useful Post: |
07-19-2010, 16:31 | #8 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
This Problem Is Due TO Diffrent Smart Card Readers In Market If U Are FAcing This Problem After Installing All Possible Smart Card Drivers Then Pls Format Ur Pc And Install These Drivers Then Check Connectivity RapidShare: 1-CLICK Web hosting - Easy Filehosting This Is due To MxKey Smart Card Readers A Selling By People's And it Takes Diffrent Ft2k Drivers Pls Check And Feed Back If Face Any Problem Contact Me On Yahoo Or Gtalk Megatronjo Or Megatron.jo Wbr <<<MEGATRON>>> | |
07-25-2010, 15:20 | #9 (permalink) | |
How is it possible to use it with e-gate smart-card ? | |
07-25-2010, 18:36 | #12 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
may be possible coz <<<MEGATRON>>> saying u can use this driver | |
07-25-2010, 18:39 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Yes, sure, a lot of people know much more than me, but you can be sure that not so many people (if any) know about Infinity-Box smart-cards more than me. |
03-01-2011, 15:10 | #14 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Alaska
Member: 672931 Status: Offline Thanks Meter: 28 | There is have difference betwen mx Smart Card Readers with Infinity Smart Card Readers. Look at pin connectorm egate need 8pin card and MX only need 6pin of card... so,,, you can just remove Infinity-Box card from your box, insert CDMA-Tool smart-Card into Unibox and you will be able to use CDMA-Tool software. |
11-29-2011, 06:18 | #15 (permalink) |
Freak Poster Join Date: Aug 2005 Location: India
Member: 173081 Status: Offline Thanks Meter: 352 | Infinity cdma range check error solution Infinity cdma range check error solution uninstall all egate driver from add/remove program in windows xp. then remove all smart cards plug into usb ports. now install Infinity-Box_Drivers_v1.4.exe, these driver installation folder created on desktop with InfinityBox Drivers folder, now run Setup_W2k_XP.exe within egate folder & fidi driver in fidi folder. now plug infinity cdma dongle in pc usb port. it will take driver automatically, if not given the path "C:\Program Files\InfinityBox\Drivers\box\e-gate_W2k_XP_Vista" with driver wizard. I have same problem, and i solve it by this method in xp, now run infinity cdma, u see range check error gone, |
The Following User Says Thank You to ajaystarin For This Useful Post: |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
