12-29-2012, 13:44 | #1 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1248435 Status: Offline Thanks Meter: 28 | samsung b219[tata docomo] india unlock problem module v1.91 Device: Samsung-SCH-B219 operation: SP-unlock Phone should be Switched ON ! connecting... checking Force mode... Force mode detected... patching in progress.. patching in progress 50%... patching in progress 100%... done... Finished, time used: 11 sec it always shows unlock done but when inserted another sim it shows invalid card how to solve this |
The Following User Says Thank You to jogichanana For This Useful Post: |
12-29-2012, 15:25 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
Which Uim Card You Have Checked Will Not Work Other Than Indian Card Wbr <<<Megatron>>> | |
12-29-2012, 15:25 | #3 (permalink) | |
01-02-2013, 03:42 | #5 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Quote:
Br. Vijendra Saini. Sent from my Videocon_V7500 using Forum Runner | |
05-26-2013, 15:22 | #7 (permalink) |
Freak Poster Join Date: Jul 2008 Location: india
Member: 816244 Status: Offline Sonork: 100.1626537 Thanks Meter: 91 | not work tata docomo b219 put in emergency mode ( press 9+ power) than insert usb cable click on sp unlock than infinity is only erase than infinity software is not responding and phone is now blinking... please update this im use win7 every driver is ok after blinking ill flash with original tool and flash file piece is ok |
06-02-2013, 08:50 | #10 (permalink) |
No Life Poster Join Date: Jan 2012 Location: prAy for nEpal
Member: 1710706 Status: Offline Sonork: 100.1645371 Thanks Meter: 61 | forum.gsmhosting.com/vbb/f633/b219-invaild-card-after-unlock-solved-unlock-done-read-inside-1400073/ already flashed with file from INFINITY support.......... any other file ????? |
06-07-2013, 08:03 | #11 (permalink) | |
Already Mentioned That Will Not Work Other Than Indian Uim Card If You Need Other Support Then We Need Operator Uim Cards To Check Wbr <<<Megatron>>> | |
05-29-2014, 13:31 | #13 (permalink) |
Freak Poster Join Date: Sep 2007 Location: The Himalayan Kingdom "NEPAL" Age: 40
Member: 580145 Status: Offline Sonork: 100.1627342 Thanks Meter: 50 | If i provide nepali cdma service provider sim then it will supported. if yes then where should i send the sim cards. wbr yash_npj |
08-30-2015, 06:43 | #14 (permalink) |
Junior Member Join Date: Nov 2012 Location: Shergarh Mathura UP
Member: 1834796 Status: Offline Sonork: [email protected] Thanks Meter: 8 | Samsung B219 CDMA Phone lock How to unlock plz help urzent |
08-30-2015, 09:34 | #15 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
If it's user lock code then connect phone to usb cable, select com port, select any samsung model and press USB safe Rebuild EFS/NV under service tab. If it is sp lock then connect Phone In Boot Mode (9+Pwr) Connect USB Cable Select Port Select Model And Press SPUNLOCK. Br. | |
