03-23-2016, 09:40 | #1 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | World's 1st Qmobile Z12 MT6735 FRP Reset And Read Factory Firmware Done Code: Operation : Format FileSystem [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D423132B5790642E90F3CDC Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB12 [eMMC] : FLASH_CID : 150100523231424D420679B5DC3C13E9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 933D5055EF2AB84E42A3C18FCBC323FC INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:47 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D423132B5790642E90F3CDC Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB12 [eMMC] : FLASH_CID : 150100523231424D420679B5DC3C13E9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 933D5055EF2AB84E42A3C18FCBC323FC INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : QMobile ProdName : Z12 ProdModel : Z12 Device : CBL7521QM AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : CBL7521QM_0101_T5365 [Read Ok] : preloader_gionee6753_65c_l1.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6753 / V1.1.2 / gionee6753_65c_l1 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 3073 MiB Scatter saved to : C:\Users\Luckey1\Desktop\MT6735__QMobile__Z12__CBL7521QM__5.1__CBL7521QM_0101_T5365\ All done! Done! Elapsed: 00:09:50 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Luckey1 For This Useful Post: |
03-23-2016, 11:25 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | MT6735__QMobile__Z12__CBL7521QM__5.1__CBL7521QM_01 01_T5365 File Size is 3GB |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
03-23-2016, 14:41 | #5 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: FLORENCE ITALY
Member: 2375239 Status: Offline Sonork: 100.1662985 Thanks Meter: 962 | I am happy to glad you superb clean bold Quote:
09-30-2016, 06:39 | #8 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Afghanistan
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | Chinese Miracle II [MTK module] v 1.56 Start at : [9/1/2015 / 11:49:21 AM] Operation : Format FileSystem [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 166 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D42313231DD0642C5228AC4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB12 [eMMC] : FLASH_CID : 150100523231424D4206DD31C48A43C5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x50E1059F2124369C2165977CC8A55C8C INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Finish at : [9/1/2015 / 11:49:36 AM] |
