Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > CDMA-Tool
Old 03-25-2011, 17:54   #1 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 549
Samsung Reliance B209 Unlock failed
Samsung B209 Unlock failed!!!
COM2 [VCP0] selected
module v1.48
Device: Samsung-SCH-B209, B309, B319, B619, B339FM
operation: SP-unlock
Phone should be Switched ON !
connecting...
Connecting, wait...
error: can't activate test mode
If phone can not be connected after several tries make this:
1. Insert original sim card in phone
2. Power-On phone
3. go to Menu, press 6 then * and type password 123456
4. go to "Port Map", HKF
5. select "UART1"
error: operation failed
Finished, time used: 26 sec
Old 03-25-2011, 18:03   #2 (permalink)
<<<MEGATRON>>>'s Avatar
Member: 1191481
Sonork: 1592603
Thanks Meter: 1,368
Hello,
What You Mean By Fail?
Did U Checked Cable ? Did U Check Weather Ur Phone Is In HFK Mode Or Note ?
Did You Tried To Input Code 47*869#123580->Port Map-HFK-UART1
Please Try These Code We Don't Expect This Type Of Childish Posting With Experianced User's
Wbr
<<<Megatron>>>
Old 03-25-2011, 18:10   #3 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 549
Originally Posted by <<<MEGATRON>>> View Post
Hello,
Wbr
<<<Megatron>>>
Yes. I checked with that code. it is UART1.
Also i tried with Boot Mode (9+Power) Also.... But same result!!!
Cable is good!!! E210 connected with Infinity Box.
Old 03-25-2011, 18:22   #4 (permalink)
Member: 1191481
Sonork: 1592603
Thanks Meter: 1,368
Hello,
B209 Will Not Work In Boot Mode Check Ur Cable Check Connector Check weather You Are Selecting Rite Port Or Not Or Try This Power Off Phone Connect Cable Press Spunlock Now Power On Phone Fast As It Shows Connecting
Wbr
<<<Megatron>>>
Old 03-25-2011, 18:28   #5 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 549
Hello,
Wbr
<<<Megatron>>>
Yes. Correct Port Selected!!!
Cable : E210 Ns Pro Cable connect with Infinity Box.
Same result!!!
Old 03-25-2011, 18:34   #6 (permalink)
Member: 1191481
Sonork: 1592603
Thanks Meter: 1,368
Same result!!!
Hello,
Your Phone Is Not Connecting Check Ur Jack Is It Ok Clean It
And Beside All These Thing's Can U try Another Cable? Or Join Me On Yahoo
Wbr
<<<Megatron>>>
Old 03-25-2011, 18:39   #7 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 1,626
Same result!!!
Dear Friend
Please Don't Put In Emergency Mode, Connect With Normal Mode
If You Have CDMA Cables Then Use Samsung B309 RJ45 Cable
Old 03-25-2011, 23:12   #8 (permalink)
Registered User
Member: 1372393
Sonork: I.M.STORE
Thanks Meter: 87
brother its ur cable problem.
nspro cable doesnt support in infinity.
use other box cable like et box etc.
Old 09-18-2011, 19:20   #9 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 177
hello megatron can u came to my shop and check all and unlock b209
Old 09-19-2011, 07:12   #10 (permalink)
Member: 1191481
Sonork: 1592603
Thanks Meter: 1,368
Hello,
Find Ur Answer Here
Samsung B209 Unlock not Done.Please help me.
Wbr
<<<Megatron>>>
Note - One Post Is Enough You Will B Replied On That Post Only
Old 11-07-2012, 16:56   #11 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 177
hi i sucesfull unlock Samsung b209 i use rj45 e210 ufs cable and direct com emulator and select com37 and open cdma tool connected com 37 unlock done. cdma is great tool and trust tool thanks
Old 05-29-2013, 03:52   #12 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 870
Hello,
Wbr
<<<Megatron>>>
Same result!!!
Originally Posted by mygsm world View Post
Dear Friend
1.Select Port (usb)
2.click usb safe rebuild EFS/NV
3.selct port (rj45) e210
4.click sp unlock and Don 100%
Old 06-01-2013, 15:23   #13 (permalink)
Member: 659347
tray to z3x box cabul
Old 06-01-2013, 15:25   #14 (permalink)
Member: 659347
tray to z3x box cabul (e210)100% okokokokok
Old 12-06-2013, 11:29   #15 (permalink)
Member: 1116231
Sonork: 1636983
Thanks Meter: 15
thanks bro its working
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 07-03-2012 13:42
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 18:06
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.36239 seconds with 8 queries
