12-14-2012, 02:54 | #1 (permalink) |
Major Poster Join Date: Sep 2010 Location: New York
Member: 1405801 Status: Offline Thanks Meter: 4 | 2 boxes dead after update... need help tried with t959, t999, i717, i747... and the same error no response from box... before was working great with Firmware Version: 1.32 [12/13/2012 2:50:31 PM] [START OPERATION_ID = RESURRECT] [12/13/2012 2:50:39 PM] Open serial port...OK [12/13/2012 2:50:39 PM] Connecting to the RIFF Box...OK [12/13/2012 2:50:39 PM] Firmware Version: 1.34, JTAG Manager Version: 1.48 [12/13/2012 2:50:39 PM] Selected Resurrector: [Samsung I747 V1.0.4707.53821] [12/13/2012 2:50:39 PM] [12/13/2012 2:50:39 PM] Connecting to the dead body...OK [12/13/2012 2:50:39 PM] Detected dead body ID: 0x406B50E1 - CORRECT! [12/13/2012 2:50:39 PM] Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK [12/13/2012 2:50:39 PM] Adaptive Clocking RTCK Sampling is: [Sample at MAX] [12/13/2012 2:50:39 PM] [12/13/2012 2:50:39 PM] Resurrection sequence started. [12/13/2012 2:50:39 PM] Establish communication with the phone...OK [12/13/2012 2:50:39 PM] Initializing internal hardware configuration...OK [12/13/2012 2:50:39 PM] Uploading resurrector data into memory...OK [12/13/2012 2:50:39 PM] Starting communication with resurrector...FAILED [12/13/2012 2:50:39 PM] ERROR: No response from the RIFF Box. [12/13/2012 2:50:39 PM] [FINISH OPERATION_ID = RESURRECT] |
12-14-2012, 08:33 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,308 | There is no problem in Box Firmware hardware ETc check the Phone pinouts be sure you connect the wire well |
12-14-2012, 10:11 | #5 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: Germany/NRW
Member: 936229 Status: Offline Sonork: 1606911 Thanks Meter: 115 | Quote:
I have same problem,Box work perfektly,after Update no Resurrection,tested on many Phones. I have Downgraded and update the Riff Box Firmware,but not work same Problem. | |
12-14-2012, 12:18 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi New Jtag Manager and New Box Firmware Work Properly Without any problem...i did resurrect more than 50pcs In the past 2 weeks So,You need Check "Pinout,usb,power supply" Or,Check with different Speed .. Please check I747 with RTCK 1MHZ Speed |
12-15-2012, 15:42 | #7 (permalink) | |
Member: 1405801 Status: Offline Thanks Meter: 4 | Quote:
RIFF JTAG Box FAQ - ERROR: No response from the RIFF Box. and im stock with this big problem | |
12-15-2012, 17:12 | #8 (permalink) |
Freak Poster Join Date: Sep 2005 Location: saudiarabia/india
Member: 185396 Status: Offline Sonork: 100.1618832 Thanks Meter: 33 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9001 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x27B360E1 - CORRECT! Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. me also having this problem pls check riff team!!!!!!!!! |
